Is it possible to replace the engine mount by using new parts?
Old Apr 17, 2026 | 04:57 PM
jagenjoyer's Avatar
Question Is it possible to replace the engine mount by using new parts?
I recently got xkr 2008 x150 and was faced with the problem of replacing engine mounts. Where I am at the moment, it is very long to wait for the original OEM parts from the catalog number (C2P20052), instead there is an announcement for sale of C2D16622, which is an OEM cushion for 3.0 V6 Supercharged RWD on XF/XJ/XE. And here's the most interesting thing: according to OEM diagrams, it sits on the same AJ813753 / AJ813754 brackets, with the same standard XR848057/ AJ811754 fasteners as the C2D2745 (5.0 XKR). According to Britcar, the dimensions are 18 × 16 × 13 cm, weight 1,191 kg. That is, according to the catalog logic, C2D16622 is much closer to C2D2745 than to C2P20052. Actually, the question is, does anyone have any experience or knowledge of whether it is possible to install C2D16622 on XKR 4.2 2008?
Please help the man from the hinterland
Old Apr 17, 2026 | 07:53 PM
Circumnavigator's Avatar
I got 2 engine and a trans mount for under $200.
I have not had them installed yet, but they look identical and everything I could find here and elsewhere says they will fit my 2008 XKR.
Old Apr 17, 2026 | 10:25 PM
RoverJoe's Avatar
Community Influencer
They will probably be exactly the same dimensionally, but I'd bet the XKR had firmer bushings in them from factory, which is why the part # is different. However, the aftermarket ones probably don't discriminate, and any you find that will fit your car will be the same as the base one anyway. I'd say go for it.
Speedmaster
Dec 20, 2025 10:08 PM
Vee
Oct 6, 2025 03:34 PM
jahummer
Aug 27, 2025 11:07 AM
wymjym
Jan 31, 2025 07:29 AM
prolepsis
General Tech Help
Dec 23, 2023 10:41 AM
