xkr strut mount
Old Jan 29, 2025 | 03:21 PM
wymjym's Avatar
Default xkr strut mount
Hey Folks,
I want to replace the upper shock mounts in a set of xkr struts.
I seem to remember that the same part # applies to several Jaguars.
Is C2P22948 the correct number? (fits XJ hoping it also fits XKR2008)
thanks
wj
Old Jan 29, 2025 | 06:22 PM
guy's Avatar
guy
I confirm part numbers here:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Jan 30, 2025 | 05:13 AM
Sailor Mike's Avatar
I bought some last month. Latest part number is C2D51875. Out of interest I am informed that these are/were made by BWI in the Czech Republic and are currently available as an aftermarket part too.
Old Jan 30, 2025 | 08:31 AM
wymjym's Avatar
to confirm, these units fit a 2008 xkr?
WJ
Old Jan 30, 2025 | 09:50 AM
I think so but it depends on VIN. You can check here: Xk 2006 - 2014 (from B00379) (x150) / Road Spring And Damper-front | Jaguar Land Rover Classic Parts They seem to fit most XKs as far as I can see but there is one exception.
Mike.
Old Jan 30, 2025 | 10:05 AM
Sean W's Avatar
I have an 07. I used C2D51875 front and back and fwiw it also fits the XJ and XF. That is correct for the mount, and the number I used interchanges with your number. I don't have a vert so couldn't tell you if they are different in the rear. Are you looking for just the mount or the spring seats too because your number (and mine) is for the mount only?
Here's the cheap stuff:
https://www.ebay.com/itm/403292368989
Old Jan 30, 2025 | 10:27 AM
wymjym's Avatar
Thanks a bunch, that url leads to a 'sold out' but the information will get me what I need. Much appreciated.
wj
Old Jan 31, 2025 | 07:29 AM
steve_k_xk's Avatar
XJ yes will fit, yet XF has a different mounting pattern (PCD) on the studs, although XF & S-Type are interchangeable.
XK8FAN
Oct 31, 2024 11:23 AM
warren8959
Dec 14, 2023 03:13 PM
Rodkel
Oct 31, 2023 01:03 AM
JayJagJay
Jan 27, 2022 11:43 AM
moonpetal38
Feb 17, 2013 08:52 AM
