Power wash Jet "O" Rings
Hi Guy's,
I have a couple of green "O" Rings at the headlamp power wash jet pipe connectors that have perished. Does anyone have a part number for these or the dimensions and type of material?
Appreciate any help,
Regards
Andy
Regards
Andy
Call the jag dealer or take the car down to an industrial supply shop and have them find a suitable substitute. It's a rubber o-ring sealing a headlight washer pipe which is a non- critical component, so don't put too much thought into it. Just find an o-ring that fits. Hell, a hardware store would be my first stop, but I don't know what all you have down there for stores like that.
Ditto, generic O ring should work fine. They'll just need to know the diameter of the material and ID of the ring. A little grease will help them go together easier.
I suspect Jag will want you to buy the whole assy.
Thanks for the advice guy's, I'll get something as close as I can from the local o-ring dude and see how I go and yes, if you purchase the assembly from Jaguar you get a free o ring!
Regards
Regards
Tony Oriente
Jan 3, 2012 03:13 PM
