Pray for me
Old Jun 30, 2021 | 12:56 PM
Glasgowjim's Avatar
Default Pray for me
Hi folks just thought I’d share. hopefully my sorry tale will help someone at some stage.
2009 Xkr, let’s go on the motorway. Flames and grey smoke out the exhausts. Restricted performance and eventually dies. Multiple misfires & bank 1 cat codes
Order 8 coils and 8 plugs, while pulling the plugs find one soaking with petrol.
Jammed open fuel injector in 1 cylinder…engine, cat and exhaust flooded with petrol.
Pull injectors and majority have bad spray pattern. Badly coked
Replace 8 injectors.
Remove bank 1 cat and clean (never again)
Engine flush twice, 14 litres of new oil, new oil filter…get rid of petrol in the crankcase
Car runs lumpy and misfires on cold start, Eml and misfire codes. Clear codes until Car heats up and runs beautifully. The new injectors and plugs make her pull better than ever.
Evap system checked
Mafs checked
All air intake checked
02 sensors checked
Fuel pumps pressure good.
Me not so good…
Today I checked the fuel trims.
Looks like the long term trim still thinks there’s a problem on start up and overfuels….closed loop / open loop
Reset car and ecu, discharged all systems. Reconnected and it fired as it should. Trims look ok.
Test tmrw morning when I cold start….
Pray for me 🙏
Keep those injectors clean, stick a bottle of wynns or similar in the tank regularly.
Don’t be me…
Old Jun 30, 2021 | 01:59 PM
Cee Jay's Avatar
Just checking here because there is a difference....
Is this a 2009 4.2 or 5.0?
Regardless, sucks a lot.
And, why Never Again on the cat clean? Huge mess?
Old Jun 30, 2021 | 03:03 PM
Glasgowjim's Avatar
5.0 CeeJay
Old Jun 30, 2021 | 03:16 PM
Cee Jay's Avatar
I think my cat on the side where my injector putzed out is a bit... questionable. I had a "Catalyst under performance" or whatever it is DTC. It went away by itself after a spirited long drive. Maybe I burned it all out.
Old Jun 30, 2021 | 05:53 PM
You have my sympathy. I had a similar experience but it happened 1200 miles from home:
If I'd been at home I'd have fixed it myself but the car spent a week in the Jaguar Dealer at Burgos in Northern Spain.
I'm not a believer in additives and found the fast drive 800 miles the length of Spain down to the Med cleaned everything nicely.
Old Jul 1, 2021 | 03:43 AM
wsn03's Avatar
I had a CAT warning and coils or ignition, cleared both, went on a 60 min drive (after just a couple of very short runs after a winter in storage) and everything was good, fault didn't come back. However mine is the 4.2 XKR
Old Jul 1, 2021 | 05:20 AM
Glasgowjim's Avatar
Cold start this morning lumpy and overfuelling, eml
Fuel pressure too high, intake system was all checked but I’ll go through it again.
trims we’re good yesterday not today
when it’s warm it runs fine
Old Jul 1, 2021 | 05:51 AM
Originally Posted by Glasgowjim
..... when it’s warm it runs fine
That makes me suspect ECT sensor.
From the Workshop Manual:
ENGINE COOLANT TEMPERATURE SENSORS
The ECT sensors are NTC (negative temperature coefficient) thermistors that allow the ECM to monitor the engine coolant temperature.
There are two identical ECT sensors installed, which are identified as ECT 1 and ECT 2. Each sensor is secured with a twistlock and latch mechanism, and is sealed with an O-ring. A two pin electrical connector provides the interface between the sensor and the engine harness.
ECT 1 is installed in the heater manifold, at the rear of the RH (right-hand) cylinder head. The input from this sensor is used in calibration tables and by other systems.
ECT 2 is installed in the lower hose connector which attaches to the bottom of the thermostat. The input from this sensor is used for OBD2 diagnostics and, in conjunction with the input from ECT 1, to confirm that the thermostat is functional.
Old Jul 1, 2021 | 06:27 AM
Glasgowjim's Avatar
I’ll look at both of them. Thanks for the help.
Engine coolant temp sitting about 80-90 when warmed up.
the car is only throwing misfire codes, not one sensor code through all of this nightmare.
Old Jul 1, 2021 | 06:47 AM
Glasgowjim's Avatar
Coolant temp at 24 when at rest. Comes up as normal on the data stream
both cats come up to temp together
trims are good again
hope I’m not chasing a piston ring.
Old Aug 6, 2021 | 04:03 PM
Glasgowjim's Avatar
Default Finally…
Hi, hope this conclusion helps someone…
As the posts above, one of the fuel injectors let go, flooded 1 cylinder, multiple misfires and the car died.
replaced 8 coils, plugs and injectors. Cold start car still misfiring, rattling and restricted performance. Clear codes, start and eventually she runs fine.
turns out when the car lost 7 cylinders it also lost mapped start up timing, tensioners are now shot, so full chain, guides and tensioners required. lucky that I still have a working engine
As now car runs lumpy on start up and eventually vvt sorts it out.
problem solved.
Known issue on the hydraulic tensioners
Old Aug 6, 2021 | 04:49 PM
Speedmaster's Avatar
[QUOTE=GGG;2410988]You have my sympathy. I had a similar experience but it happened 1200 miles from home:
...and found the fast drive 800 miles the length of Spain down to the Med cleaned everything nicely...
I once drove a Citroen from Salamanca to Cadiz/Marbella/Granada...at speed. I am pretty sure that rental car is trashed now.
Old Aug 6, 2021 | 04:52 PM
George05's Avatar
[QUOTE=Speedmaster;2425307]
Who done the work Jim ?
Old Aug 6, 2021 | 11:40 PM
steve_k_xk's Avatar
Although a 4.2 just did my tensioners, chains and guides this week.. word of advice only use OEM parts please
Old Aug 7, 2021 | 09:03 AM
This motor looks a lot like my E38 M62TU BMW motor. Timing chain guides routinely fail on those.
Old Aug 8, 2021 | 05:53 PM
Glasgowjim's Avatar
[QUOTE=George05;2425308]
hi George.
going in to Ali Macmillan. Finally found someone who can look after it.
always work in progress to bring it back. 😂
Old Aug 8, 2021 | 05:54 PM
Glasgowjim's Avatar
Spoiler
Big job Steve, well above my pay grade 😂
Old Aug 9, 2021 | 12:27 AM
wsn03's Avatar
What sort of mileage should that be done at?
Old Aug 9, 2021 | 12:01 PM
George05's Avatar
[QUOTE=Glasgowjim;2426006]
Originally Posted by George05
hi George.
Macmillan get a very good name , all the guys from the jaguar drivers club and jaguar enthusiasts club use them been going over 50 year , car is in good hands
gbmarc
Aug 20, 2021 09:11 PM
ka1thm
Aug 2, 2011 08:00 AM
Cambo
Diesel variants - All models
Jul 14, 2011 12:43 PM
BadCat
Feb 21, 2011 03:23 AM
Norgards
Jun 30, 2010 04:21 PM
