Premium or Standard Audio
Old Aug 11, 2022 | 01:55 PM
MudDog's Avatar
Default Premium or Standard Audio
How to determine 07 XK
Yes I have 6 speakers , plus a grated opening in the center of the dash. Im only asking cause Im getting Amp DTICS and one of the questions is there a Amp Installed , Like How do I know ???
Shop manual is a little vague on difference physically
Old Aug 11, 2022 | 02:27 PM
kj07xk's Avatar
Pull back the carpet in the passenger footwell, an amp, if you have it, will be mounted behind a panel there.
Old Aug 11, 2022 | 03:07 PM
mosesbotbol's Avatar
Are they Alpine speakers?
Can you run the VIN to print out a window sticker?
Old Aug 11, 2022 | 04:21 PM
MudDog's Avatar
found this on the car fax I ran.
I see yes on amplifier and Alpine on Speakers that makes it Premium ?
Old Aug 11, 2022 | 04:33 PM
Sean W's Avatar
Yes that makes it premium. To access the amp you need to remove the passenger seat and then remove the carpet (it's molded to fit in place and doesn't pull back well). the amp will then be under a plate on the upslope.
Old Aug 11, 2022 | 06:26 PM
Sean W's Avatar
There is also the Premium Bowers and Wilken's system in the later models, referred to as premium as well.
Old Aug 11, 2022 | 06:50 PM
u102768's Avatar
See if you have an entry for a sub in the audio settings. If you do you have premium.
Kevin Green
Jun 27, 2016 03:20 PM
smoggyx100
Jun 1, 2015 03:30 PM
raschwar
Jul 2, 2014 10:57 AM
Michal
Audio/Visual Electronics
Jun 25, 2010 03:10 PM
JordyO
Sep 8, 2009 01:24 PM
