Preperation for new set of pilot 4s's
Old May 5, 2023 | 03:16 PM
bocatrip's Avatar
Default Preperation for new set of pilot 4s's
After 9 1/2 years of ownership, I'm finally getting ready to replace my original Dunlops on my 2010 XK Coupe (15,000 miles) with a fresh set of Michelin Pilot Sport 4S. Expensive, but well worth it for me. I'm even getting the Michelin promotion for $150! lol. Question....Is there anything I should be prepared for with regards to the tire sensors as all four are original? I have not had a problem with them. Does anything need to be reset after the install? Is it advisable to change all the sensors while getting the new tires due to the sensor's battery life of 8-10 years? or, should I not replace what is not broken. Thanks all.
Old May 5, 2023 | 03:37 PM
Cee Jay's Avatar
The car needs to be driven for like ten miles for the car to relearn the sensors. For YOU though, that may take a few months.
Old May 5, 2023 | 03:58 PM
Sean W's Avatar
change the sensors now and save on labor. They're past their prime @ 7 years. Drive around at a constant speed for 20 minutes (above 50) and you are will learn the new ones. You'll know it happened when the warning light goes out.
Old May 5, 2023 | 04:23 PM
bocatrip's Avatar
Thanks Sean. Where might be the best place to purchase the sensors? I assume Jaguar is out of the question...What is the brand and possible part number for the sensors? Thanks again.
Old May 5, 2023 | 04:56 PM
Jaggyx's Avatar
I agree that now's the best time to replace sensors. Definitely don't buy the sensors from Jaguar. Read this thread, post #9: https://www.jaguarforums.com/forum/x...ensors-241304/
Old May 5, 2023 | 05:23 PM
bocatrip's Avatar
Can anyone recommend where and what brand tire sensors should be purchased for our XKs? The pricing is all over the place and I do want to get fresh stock for the battery life of the sensor. I believe the installer/vendor of the tires... BJs sells the sensors, but I'm somewhat leery as to the quality of them. Thanks all.
Old May 5, 2023 | 05:28 PM
Cee Jay's Avatar
Siemens VDO 53004 TPMS
Old May 5, 2023 | 05:44 PM
bocatrip's Avatar
Thanks Cee Jay. Too bad there are not many of the "Old Timer Members" left that still have such a wealth of info. I guess as our cars age, only the true dedicated stay with their beloved car as the others move on to the newest and best. It seems to be a theme in many forums. Thanks again.
Old May 5, 2023 | 05:54 PM
bocatrip's Avatar
Is $100 really the going rate for this sensor? $400 a set seems excessive. Any place to get them at a discounted price?
Old May 5, 2023 | 05:59 PM
McJag222's Avatar
Couldn't find the ones Cee Jay mentioned:
https://www.stockwiseauto.com/auto-p...guar&Model=XKR
Old May 5, 2023 | 06:03 PM
Cee Jay's Avatar
Evidently they changed their part number:
Amazon Amazon
Old May 5, 2023 | 07:36 PM
u102768's Avatar
The replacement for the 4S, the S5, has started shipping in a small range of sizes. Wouldn't it have been worth waiting for those to become more generally available or were the Dunlops too worn?
Old May 5, 2023 | 07:47 PM
Cee Jay's Avatar
I COULD refresh everyone's memory on why I consider every Michelin tire a total piece of donkey crap....
Old May 5, 2023 | 09:58 PM
Stuart S's Avatar
You said that you are buying the new Michelins from BJ's Warehouse Club. You should have them supply and install the new TPMS sensors because they will be responsible for the warranty. Note that the correct sensors are plug-and-play, and need no programming.
Make sure that the tire installer uses hand tools only to remove and reinstall your wheels, as an air wrench can damage the 2-piece lug nuts. Also, make sure the installer uses the correct size (19mm) socket - one came with your XKR - and not the closest size SAE socket (3/4"), which is a wee bit too big and will bugger the corners of the outer shell and cause it to spin on the inner nut.
Also. note that the correct torque spec is 92 ft.lbs.
Read this entire thread, in particular my Post #6:
https://www.jaguarforums.com/forum/x...g-nuts-210103/
Old May 6, 2023 | 10:12 AM
bocatrip's Avatar
Stuart, Thanks for the more than helpful advice. However....I'm a little hesitant in expecting the tech at BJs (who I happen to know) to be willing to pull every wheel nut off my car by hand. Of course I'll ask when I see him (as well as compensate him) and just hope he's accommodating. If not, I may just go to another independent shop that will, and pay the extra bucks to get it done right. PS. I happen to remember the first and only time I had my tires removed when I purchased my car well over 9 years ago.. getting my OEM brakes replaced with ceramics and I'm pretty sure that shop did not do the removal of my wheels correctly. I remember them using power tools. I'm just hoping they didn't screw things up.
Old May 6, 2023 | 10:33 AM
Sean W's Avatar
Yeah, Jaguar recommends Siemans and we have the 315 MHz model. You can pick from here. Note, Continental bought Siemans in 2007.
I entered you car info here:
https://newparts.com/shop/?category=...em-tpms-sensor
Old May 6, 2023 | 03:19 PM
Tracee's Avatar
I don't even bother the tyre "techs" with the proper torquing; I get the car home, loosen the nuts and torque them myself, criss-cross.
Old May 6, 2023 | 04:18 PM
bocatrip's Avatar
I'm thinking of asking BJs to replace all the sensors with their stock sensors. If 315mhz is the criteria and the XK sensors are not programmable, there shouldn't be a problem as it would pretty much be plug and play. I was just wondering......If they are using a 19mm socket, wouldn't they be able to use a power gun to remove the nuts without damage to them? As far as installing the nuts, I can always ask to have them put on by hand and then the torque wrench. I'm just reluctant as to whether the tech wants to remove that many wheel nuts by hand.
Old May 6, 2023 | 04:30 PM
Sean W's Avatar
let us know what brand they install. Order yourself a 1/2" drive non marring socket and bring it with you, ask them to use it.
Old May 6, 2023 | 05:14 PM
bocatrip's Avatar
I can and will certainly do that. Will the non marring core/sleeve be narrow enough to fit through the opening to the lug nut?
