Problems with convertible top on 2007 XK
Old Sep 21, 2022 | 06:31 PM
optomeyes's Avatar
Check that the divider panel in the trunk is properly seated. If it got knocked out of position, the roof mechanism will not work. Make sure it is vertical and properly seated at the base of the divider.
Old Sep 21, 2022 | 07:19 PM
Cee Jay's Avatar
Originally Posted by britishracer
PULLED ON THE CORD NEAR THE HYDRAULIC PUMP
Hi Forum,
I recently had problems with my convertible top. While investigating what was ultimately low hydraulic fluid in my pump, I stupidly pulled on the small pull cord near the pump and now I cannot get the top to operate. I get the message "Top Unlocked". Can anybody suggest a way to correct the situation?
Patrick
That small pull cord releases the tonneau cover. Press around on the front and side edges of the cover, see if you can get it to re-latch.
Old Sep 21, 2022 | 10:13 PM
britishracer's Avatar
Is that what this pull cord is for? When the problem started the top was raising with difficulty and I could hear the whining noise of the pump that didn't have enough oil to operate. But now nothing works at all. I get the "top unlatched" message in the dashboard information window but the pump does not engage. Nothing happens.
Old Sep 21, 2022 | 10:14 PM
OK I will try that tomorrow.
Old Aug 4, 2023 | 06:01 PM
StanS's Avatar
Default problem with conv. top function - HOOD NOT LATCHED. it seems as electrical problem.
Have anybody electrical scheme for XK 150 MY 2007 ? I cannot find it.
Old Aug 4, 2023 | 09:18 PM
kj07xk's Avatar
There’s a sticky at the top of this forum with the electrical guides. Select the one which includes your VIN.
Old Aug 4, 2023 | 09:21 PM
Stuart S's Avatar
See the Sticky Threads at the top of this Forum and scroll down to the XK/XKR Workshop Manuals & Electrical Guides.
Old Sep 6, 2023 | 02:38 PM
  #28
James Alexander's Avatar
Default Battery replaced now stopped3in up no nothing
Battery replaced went to put top down thing unlatched windows down and top started to move up from windshield 4 inches and stopped. Now nothing
tried to relieve pressure on pump. Still couldn't overpower the top.
While messing with pump i noticed the pump was really hot. Fluid level looks ok.
Your ideas please.
Old Sep 7, 2023 | 07:45 AM
Default 07 XK top stopped on way up now nothing.
Originally Posted by Cee Jay
I'd say your pump is on the way out. Ten-Eleven years of year round usage several times a day can take its toll. So would a few times a month.
cee-Jay.
Had battery replaced . Put top up prior to new battery. R&R battery job comp. Went to drive car home oh well lets put the top down. Windows down windshield unlatch and top moved up 3-4 inches and now nothing. 07 XK. ???
Old Sep 7, 2023 | 08:25 AM
  #30
WhiteXKR's Avatar
Front windows need to be reset after battery change for top to work properly. See owners manual or other threads on the subject.
Old Sep 7, 2023 | 08:47 AM
  #31
v8deuce's Avatar
About 10 posts back from your is a description of how I reset mine with the drivers window switch reset it worked for me although it took a few tries.
Randy
Old May 10, 2024 | 01:31 AM
  #32
Geosnooker2000's Avatar
I'm having a problem I haven't seen anyone else complain about. When I try to lower the top, it "tries", but it sounds like whatever latching system is in the top of the windshield frame will not let go of the ragtop. It goes click, click, click, click, like some gear is stripped out or something. Is there a way to get it to manually unlock from the windshield frame?
Old May 10, 2024 | 07:07 AM
  #33
kj07xk's Avatar
I suspect you do sort of the reverse of the manual reset procedure in the owners manual and use the allen key to release the overhead locks.
Old May 10, 2024 | 10:19 AM
  #34
slick.one's Avatar
Hold the "top down" button for a 10 count and it will continue to lower.
Old May 13, 2024 | 10:19 PM
  #35
Thanks I will give it a try!
Old Jul 22, 2024 | 11:17 AM
  #36
Mikesoja's Avatar
Originally Posted by optomeyes
Lately I’ve had problems with opening and closing the top to my 2007 XK. Very slow opening and sometimes needs some manual help. When trying to close, it starts coming up a couple of inches and can’t go any further without help. I checked the hydraulic fluid level and it’s at the full mark. I assume it’s the original fluid.
Any suggestions??
Just to add, if anyone is experiencing this I also had it the exact same where I'd press the open button and it would unlatch go up a couple inches and everything stops and all I hear is the motor trying and I'd have to proceed to open the rear hood and move it all by hand to get the top down or up as well. Looks like my battery was the issue!! I connected a booster and it worked like new so I realized my battery is strong enough to start the motor but not enough to power the soft top 🤷🏾‍♂️ anyways test that out if anyone's experiencing these symptoms!
Old Jul 24, 2024 | 11:30 AM
  #37
justinhill's Avatar
Being both pedantic and paranoid, I've never raised or lowered the roof without the engine running.
Old Jul 24, 2024 | 11:36 AM
  #38
Cee Jay's Avatar
I operate my roof somewhat frequently, and remotely, using Steve's contraption. It's especially cool when I lower the roof while walking to my car and people are nearby wondering What the Heck.
Old Jul 24, 2024 | 11:50 AM
  #39
Mikesoja's Avatar
I seemed to have the issue even with the engine running, and only when I added the noco booster did I notice normal operation of the softop.so I'm guessing I'll need a new battery, so once I get it I'll update everyone on how the softop operates!
Old Jul 24, 2024 | 11:59 AM
  #40
justinhill's Avatar
I must admit I am tempted by the idea of one of these gadgets. Not so much for being able to to operate it from outside the car, more because of feeling like an idiot who's got his finger stuck in the headlining. Why it wasn't one-touch from the factory is a mystery to me.
