Problems XK 2006
Old Nov 8, 2017 | 11:38 AM
Kevin Seegers's Avatar
Default Problems XK 2006
I am a proud owner of a XK since a few months and still have 6 months warrenty on it.
I have two problems with the car that the dealer can't find. The first one is once a day when the car is cold and i start it up. I set it in to drive and let it roll and then push the gaspedal slightly.. what happens then is that the car holds in.. and stutters a little? Like the gas can't go anyware.. When i push the gaspedal a little more it's true it's dead point and the car performs normal? And this is only when the car is cold.
Now the second thing i suddenly had a few days ago is this: I drove for like 20 min and stopt the car.. locked it with the button (pressed it one time) after 5 min i came back. open my door directly with my hand and suddenly no power at all! nothing worked anymore. the key didn't react only the button to make the lights go on worked... Then suddenly after 10 min or so, after pressing the lock and unlock button on the key again the car reacted??
I hope somebody has the solution for this. It would be very helpful.
Sorry for my not perfect english i'm from the Netherlands
Old Nov 8, 2017 | 11:46 AM
Ranchero50's Avatar
#1 define how long after startup you are trying to go.
#2, battery replacement time. Search the forum, pretty much any electrical anomaly is resolved with a new battery.
Old Nov 8, 2017 | 12:02 PM
1 right after start up when driving away from the parked spot
2 sic months ago the battery was changed for a new one
Old Nov 8, 2017 | 12:55 PM
michaelodonnell123's Avatar
The title says XK 2006 - are you in the right forum? Is yours an XK8 or an XK? The XK8 is the old model and the XK is the new model.
Old Nov 8, 2017 | 01:12 PM
Ranchero50's Avatar
#1 without it throwing a check engine light, the processor is getting a faulty input but not bad enough to trip a code. Cold makes me think o2's or similar temp related inputs. Dealer should have been able to look at those data points as it warmed up and messed up. Did they say if they were able to duplicate the fault?
#2 is interesting. These cars use a data bus for one module to talk to another. Voltage / current spikes creates havoc with the signal which is why the battery suggestion. Still a ton of possible things to look at. Mostly wiggling wires and connections while the electronics are acting up.
Old Nov 8, 2017 | 01:47 PM
it’s the x150 so the newermodel with the 4.2 engine
Old Nov 8, 2017 | 01:51 PM
NBCat's Avatar
In Europe the X150 went on sale in 2006.
Old Nov 8, 2017 | 01:54 PM
NBCat's Avatar
With the ignition in the off position, the voltage across the battery terminals should be a minimum of 12.5 volts. If not, the battery should be replaced. A weak or failing battery can cause all sorts of mysterious electrical faults.
Old Nov 8, 2017 | 02:45 PM
DaimlerMK2's Avatar
in the UK, we see x150,xk on a 55 plate. that's 2005,and 55/2006.
Old Nov 8, 2017 | 02:47 PM
Ranchero50's Avatar
Thumbs up
Good point. Could be the OP has a classic case of not driving it enough or no aux charger for while it sits. That would also exacerbate the drive ability problems.
