Promises, promises... dyno day ecu flash results
Old Mar 6, 2017 | 04:03 PM
AlexJag's Avatar
Sponsor
Default Promises, promises... dyno day ecu flash results
So without going into too much details just yet.
Here are the results of stock vs Eurocharged caned tune. Mustang Dyno used
All done same day similar temperatures. Stock peak RWH 359, tuned peak whp 366...
They just did a calibration of the dyno before my car, for references a newer z51 corvette with headers put down 420 whp .
Comments from the dyno operator/tuner "way too rich, only timing parameters were changed on top end" This confirmed my initial tune impressions, felt no different than stock. These issues I had already tried to address with Jerry prior to the dyno session.
will be asking for my money back
Attached Thumbnails Promises, promises... dyno day ecu flash results-20170303_132005.jpg
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Mar 7, 2017 | 03:43 AM
1 of 19's Avatar
So how much did 7 hp cost? I've been contemplating a tune only because I modified my cats and would like the codes it's now throwing tuned out.
So I thought while "they " are messing around might just as well add some HP. But... maybe not!
Old Mar 7, 2017 | 04:28 AM
steve_k_xk's Avatar
Donr ut a rubbish blanket on all tunes as stated previously I have gained 25whp and .5 off my e.t but that was with a custom dyno tune
Old Oct 12, 2019 | 03:25 AM
XJR-99's Avatar
Long time ago: 4.0 , 2.6H TS with 1.90 SC ratio ( 16.7PSI ) and AFR 12.5 : 522bhp / 640Nm Stock tune. AFR 11.5 - about 8hp less.
EDIT: wrong thread
Old Nov 5, 2020 | 12:05 PM
Zues's Avatar
Waking the dead. What ECU is being used here?
Old Nov 5, 2020 | 01:56 PM
jahummer's Avatar
The 4.2 X150 is Denso, the 5.0 is Bosch.
Old Nov 5, 2020 | 03:37 PM
AlexJag's Avatar
Sponsor
I will correct you a little 5.0 XF xfr Xk XKR and probably xj up to 2014 are denso as well, or at least all the ones that I have tuned. 2014 XKR last month was Denso , two XFR s over the last few months were also Denso . Maybe I just haven't run into the Bosch ones but I suspect they are all Denso till 14
AlexJag
Jul 30, 2016 09:20 PM
AlexJag
Jul 15, 2016 05:32 PM
MaximA
Apr 21, 2014 07:06 PM
SoCal Babe
Mar 13, 2014 03:56 AM
budsang1
US Midwest
87
Jun 11, 2010 09:14 PM
