Promising Valve cleaner and injector cleaner
Old Nov 6, 2019 | 09:33 AM
Queen and Country's Avatar
Default Promising Valve cleaner and injector cleaner
This is from a very trustworthy company- every product they make is outstanding.
Doing it just for the 5% HP gain is worth it.
They show proof @7:00 min mark
Old Nov 6, 2019 | 10:00 AM
drumcarfar's Avatar
So would this have to be sprayed in through the intake before the supercharger? And wouldn’t that eat away at the coating on the supercharger rotors?
Old Nov 6, 2019 | 10:08 AM
No for 2 reasons.
PEA does not eat anything, its not an acid. Its an oil that penetrates porous carbon, and requires heat.
Old Nov 6, 2019 | 10:23 AM
Stuart S's Avatar
Thanks again.
P.S. Available at your local auto parts store for less.
Old Nov 6, 2019 | 10:33 AM
Sean W's Avatar
I saw Scotty Kilmer video where he used it by finding a vacuum line and spraying it it there. He didn't show the before or after results but I'm guessing one could spray it in a vacuum line and not have to worry about the MAF sensor. I dunno.
Old Nov 6, 2019 | 10:42 AM
jackra_1's Avatar
CRC label specifically warns not to spray the MF sensor.
I have some and intend to use it on my 2013 Rover.
Old Nov 6, 2019 | 10:49 AM
Stuart S's Avatar
The MAF sensors are located at the exit of the air cleaner boxes, which are not easily accessible. See the diagram below for the 4.2L SC engine. I suspect that the 5.0L is similar. My question is: what would you disassemble in order to spray the CRC Cleaner into the intake system? What's easiest?
Old Nov 6, 2019 | 10:54 AM
Stuart S's Avatar
Originally Posted by jackra_1
CRC label specifically warns not to spray the MF sensor. ...
Is that MF sensor X-rated?
I think you meant MAF.
Old Nov 6, 2019 | 10:59 AM
Cee Jay's Avatar
I don't like how the 'proof' is piecemeal from various vehicles. Why not show ALL those parts from all the test subjects?
Anyway, this is how I'd do it:
Old Nov 6, 2019 | 11:10 AM
The eye-opener for me was the cleaning of the injector from the exterior and getting them back to new.
It explained the failing injectors.
Old Nov 6, 2019 | 12:09 PM
Sean W's Avatar
I think you could just loosen a clamp past the MAF sensor enough to slide the CRC tube in and you'd be fine without having to tap a line. And yes there a several videos out there with demos or CRC vs. water vs. Seafoam. Some are a bit "Appalachian" and rather entertaining, albeit useless. One just does a compare leaving the piston head soak, though he acknowledges he's not following the directions. This one is my favorite:
Old Nov 6, 2019 | 12:13 PM
peppersam740's Avatar
If you want to keep your injectors clean you need to use a injector cleaner run through your gas tank.
Old Nov 6, 2019 | 12:30 PM
gkubrak's Avatar
When I used Seafoam I loosened up the intake resonator to the T-pipe. Then stuck the nozzle spray tip in a small gap between the T-pipe and resonator. This was a crappy method because you can't see where it's actually spraying. It ended up shooting over the throttle body and across to the resonator on the other side lol. Soaked my air filter and didn't even realize it.
If you can rig an adapter to fully seal the spray tip inside the vacuum hose, I would spray it through the brake booster vacuum hose - before the check valve.
Next time I will run it through a service port I have in my catch can (AKA the dip stick hole).
Old Nov 6, 2019 | 12:38 PM
jackra_1's Avatar
https://www.youtube.com/watch?v=48JSlXlvMC0
My inlet pipes are very rigid. I doubt that I could just loosen a clamp and slide the CRC tube in. I was thinking about taking one of the two MAF(got the spelling correct this time) sensors out and masking the hole then poking thru the masking. Not so worried about the engine running rough for a while but I do not want a code thrown that
is difficult to get rid of.
Old Nov 6, 2019 | 12:58 PM
Sean W's Avatar
Agreed. I think the purpose of Q&C's post was primarily to focus on the carbon build up on the injectors for the 5.0 engines as they are direct inject.
BTW, I use BG44 fuel system cleaner. $30/ can
Old Nov 6, 2019 | 01:03 PM
gkubrak's Avatar
You might end up having the same issue as i did - soaking the resonator and air filter. Since there won't be much vacuum or 'suction' @ 2000-3000 RPM to pull the liquid into the intake. It will just drip down to the air filter.
Old Nov 6, 2019 | 01:07 PM
jackra_1's Avatar
Good point.
Old Nov 6, 2019 | 01:20 PM
The injector cleaner you run through the tank and this is the exact same thing. The spray is more concentrated.
In fact the injector cleaner I run through my tank is made by CRC.
https://www.crcindustries.com/produc...-oz-05815.html
But If this does valves, piston heads, and injectors.....well the injectors are a bonus.
The thing to keep in mind in a DI engine its not the fuel path that's causing the injectors to get clogged up, no way even running the lowest quality gas would an injector clog under 75k miles, as its doing on our 5.0 engines.
Clearly its crud from outside the fuel system, so it makes sense that an external cleaner is having effect without even trying.
For the conspiracy theorist ding-dongs among us, I have some relief, if this company sells separate fuel injector cleaner, why would they mention it as a free bonus to one of their other products, if not for honesty. Seriously- BK44 makes you do both, run the stuff through the tank and intake, at 5x the price.
Old Nov 6, 2019 | 01:56 PM
jahummer's Avatar
If it is GDI then tank cleaner will do little good for dirty valves. For GDI you have to use the cleaner directly through the throttle body.
From CRC:
If you have a GDI engine, this is a necessary process to keep your engine healthy. In-tank fuel additives have zero effect on GDI intake valves as they never see fuel washing over them. In-tank cleaners are great for “wet” valves, but not so much for “dry” valves.
https://www.crcindustries.com/how-to...turbo-cleaner/
Old Nov 6, 2019 | 02:54 PM
jackra_1's Avatar
From CRC:
Everyone on this thread knows that as far as valves are concerned on a GDI engine.
As far as running CRC directly thru the TB how does one do that? No way could I do that on my engine.
