pulling wiper arms
Old Jul 1, 2015 | 05:43 PM
RedRider48's Avatar
Default pulling wiper arms
Hey Guys,
How difficult is it to remove the wiper arms from their posts ('08 XK-R). In other vehicles, I've needed a puller of some type. Once removing the nut, what should I expect? Stuck to the stud, or easy peasy lift off?
Doing this makes detailing that area, so much easier.
Thanks for any insight.......
Old Jul 1, 2015 | 06:22 PM
kj07xk's Avatar
The first one I tried to remove on my '07 XK wouldn't budge, so I got a 'battery terminal lifter' tool to loosen it, as I didn't know exactly how it was held on.
After taking that first one off, I determined that I could accomplish the same thing by 'rocking' the arm on the post to loosen it, which is what I did with the other arm, and it came off without having to use the lifter tool.
Old Jul 1, 2015 | 10:00 PM
RedRider48's Avatar
Thanks Ken,
I'll proceed with "hope", "faith", and "caution".....Ha, Ha...
Old Jul 2, 2015 | 09:09 PM
RedRider48's Avatar
Hey Guys,
Wiper arm removal update....
After removing the cover cap and the nut (13mm), I gave the post a shot of PB Blaster and let it stew for an hour, or so.
Using a nylon pry and soft cloth, I applied light upward pressure while slightly wiggling the arm in different directions. Each broke loose after a little effort.
Thanks for your advice.
Attached Thumbnails pulling wiper arms-img_0244.jpg   pulling wiper arms-img_0247.jpg
johndahlheimer
Sep 17, 2020 03:10 PM
CaneCounsel007
Nov 13, 2015 09:05 PM
British Ride
XJ40 ( XJ81 )
Sep 18, 2015 01:57 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
XJsc-guy
Sep 2, 2015 11:43 AM
