Radio n separate nav unit working occasionally 05, xk8
Old Apr 24, 2020 | 05:55 AM
Lincoln Colt's Avatar
Default Radio n separate nav unit working occasionally 05, xk8
Please help, most of the time the stock alpine radio, factory antenna, and separate NAV screen located on center of dash instead of the three analog dials Will not power on/work. Periodically when I driving I’ll press the radio button and everything will work perfectly. When I turn the car off and then go to drive it again it’s back to being an operational until the next time it decides it wants to turn on. What could it be? I check the connections for the radio and the separate naff unit and all seem fine please any suggestions. Sidenote, I don’t know why they make it so difficult for fuse locations there’s nothing that I can find to show me what all the fuses are for. I’m thinking it’s a loose wire somewhere it can’t be a bad fuse because then it wouldn’t come on is that somehow wired into the ignition switch?
Old Apr 24, 2020 | 08:36 AM
Sean W's Avatar
You're in the wrong Forum. This it the X150 forum. You want to ask your question in the X100 forum here:
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
Or ask a moderator to move it for you
Binderminder
May 2, 2017 03:55 PM
jagincumbria
Oct 22, 2015 11:19 PM
Shadow993
Feb 13, 2012 09:15 AM
RDAutomobiles
Jul 23, 2011 05:03 PM
Bull27
44
Jul 6, 2010 11:01 PM
