Rear E Brake
Old Feb 8, 2025 | 05:22 PM
badicedog's Avatar
Default Rear E Brake
Can someone please post a picture of the Emergency brake caliper and bracket? The last step in the Alcon conversion is the R-brake. I’m getting an audible (annoying) audible warning… the only way it seems to get rid of this is to change the rear Hub and install the XKR tear E brake. Thank you
Old Feb 8, 2025 | 05:38 PM
McJag222's Avatar
I thought you might have issues with the e brake - not even sure if the e-brake "motor" is compatible with the original.
Old Feb 8, 2025 | 06:18 PM
badicedog's Avatar
Thank you so much
Old Feb 10, 2025 | 10:52 PM
badicedog's Avatar
Update….the dreaded alarm chime from the E-Brake was driving me insane!!! I resorted to physically unplugging the E Brake control module behind the rear power junction box. It’s a temp “fix” until I acquire the necessary part to properly remedy this.
Old Feb 11, 2025 | 12:55 PM
jahummer's Avatar
As I mentioned in one of your other threads, the EPB module's different for the Alcon fitted cars. I used the standard one and routed the cables differently and had to perform a calibration with SDD to get the annoying alarm to go away. Then sometime later the module failed.
bjg625
Mar 19, 2023 02:25 PM
biggles1940
General Tech Help
Nov 28, 2022 09:27 AM
Pistnbroke
May 14, 2022 01:35 AM
mpasiuk
Mar 15, 2021 07:55 PM
