Rear End Handling Issues ?
Old Aug 18, 2023 | 12:54 PM
rjkxk150's Avatar
Default Rear End Handling Issues ?
Hi Everyone , i'm hoping someone can assist with the concerns i have with my 2006 XK150 ... it's just the standard base model 4.2 auto and with the 20 inch wheels and i can't explain how much i love this car , it's an amazing beautiful piece of machinery . The problem i'm having is in the rear end of the car and it appears to happen more on a decline and in dry or wet weather that the rear end feels like its sliding out ... it actually feels like your losing control of the car and it actually feels scary unsafe ... has anyone else experienced this problem ? Any help would be greatly appreciated ... Thank you Ray
Old Aug 18, 2023 | 01:18 PM
wymjym's Avatar
I have not, mine is very well planted. Suggest you get it on a lift and look for loose or worn suspension pieces. Of course if you have dunlap tires on it that is typical, slip sliding (from my experience)
wj
Old Aug 18, 2023 | 03:36 PM
Cee Jay's Avatar
Your car is old. Bushes and such wear out with just age. There are threads in this forum with ways to repair this. Also tires affect handling, of course.
Old Aug 18, 2023 | 04:15 PM
rjkxk150's Avatar
Thanks for replying , i'm dropping it to my mechanic today and i'll mention your advice . The problem first become apparent a couple of weeks ago on a short trip i did and automatically i thought tyres so i had four new Michelins put on last week but the issue was still there .
Old Aug 18, 2023 | 04:25 PM
rjkxk150's Avatar
Thanks for your reply and yes its getting old but its always extra well maintained but i;m hearing what your saying and i'll mention that to my mechanic and i'll look for some threads re this issue .
Old Aug 18, 2023 | 08:01 PM
guy's Avatar
guy
anti sway bar bushes are overlooked, as are worn dampeners.
Brand of tire does matter, but so does the model.
Not to mention your management of speed and throttle control. And brake before the corner, not in it.
Old Aug 18, 2023 | 10:41 PM
CurtJ's Avatar
I had the rear control arms and bushings replaced and it made a world of difference in the feel of the rear end.
Old Aug 19, 2023 | 12:32 AM
rjkxk150's Avatar
Thanks for the info Guy
Old Aug 19, 2023 | 12:36 AM
rjkxk150's Avatar
Thanks CurtJ , i'm going to have all those items looked at . Cheers
Old Aug 19, 2023 | 02:21 AM
Damirich's Avatar
Also i would advise to check tire pressue, and remember that pressue of front and rear tyres is different.
Old Aug 19, 2023 | 06:07 AM
guy's Avatar
guy
@Damirich , Only as you bring it up. For my summer setup, I drop the pressure in the front and rear by 5%. It feels better in the corners… (pilot sport 4 s).
Spring and fall (pilot sport AS4) Im running -5 % in the rear. -10 % in the front.
Winter (yes you read that right),…. well, there’s some history here. I like the blizzaks on ice, the michelins on snow… historically was -10% all around. But because of all you guys, I’m going to try the Vredesteins this year.
Each time I get new rubber, its about 2 weeks of trial and error to get it feeling right, again.
@rjkxk150 , once you have the suspension and alignment done, check out the differences in the rear end by altering the pressures back there. Do Not overinflate! The handling and grip will suck…. she will bounce like crazy.
But do try a spirited drive at rated, then -5%, then -10%. (all cold of course). The differences are quite pronounced.
Old Aug 19, 2023 | 10:10 AM
wymjym's Avatar
and of course a bad wheel alignment can cause a multitude of unwanted behaviors
wj
Old Aug 20, 2023 | 07:37 AM
Tiepolo's Avatar
To me that sounds like the rear arms and silent blocks (is it what you all call bushings?) needs to be replaced.
Nothing exceptionnal with this mileage @rjkxk150 .
I do feel the same on mine too and plan to have it done next month.
dbritt320
Aug 28, 2023 02:10 PM
W3IKE
Feb 19, 2023 01:43 AM
Al G
Dec 22, 2021 08:36 AM
Allycat
Jun 29, 2021 11:56 AM
CorStevens
Jun 6, 2017 08:50 AM
