rear fender mud guard
Old Aug 16, 2023 | 04:55 PM
wymjym's Avatar
Default rear fender mud guard
sorry, don't know the correct term but I just noticed this different placement...anyone know if it was a mistake or something else? My 2008, with 20" wheels
is mounted rearward
wj
Old Aug 16, 2023 | 05:41 PM
Known as a Wheelarch Spat (see item 14):
The same as mine.
Old Aug 17, 2023 | 02:57 AM
justinhill's Avatar
Out of interest - did all XKs and XKRs come with these spats? They're listed on my car's build sheet looking like an option.
Old Aug 17, 2023 | 04:37 AM
It some time since I read it but I recall it was a Construction & Use design requirement because the wheel protrudes slightly beyond the rear wing. My 2005 XK8 had the same spats although earlier model years did not.
My 2006 XK didn't have them.
Old Aug 17, 2023 | 07:29 AM
Tiepolo's Avatar
My 2008 xkr doesn't have it. (and I'm glad about it, it's ugly).
Maybe that's an american thing.
Old Aug 17, 2023 | 12:06 PM
kj07xk's Avatar
What size wheels were equipped on your car from the factory?
I seem to recall reading that the spats were equipped on an XKR if it had 20” wheels. None for the XK.
Old Aug 17, 2023 | 12:19 PM
justinhill's Avatar
I'd been wondering about that myself - whether the original wheels dictated the spat. Presumably, it would be the width of the tyre that matters - 285mm in the case of a 20" rim - and so an XK (i.e. non-XKR) would get them if originally specified with optional 20" wheels.
Old Aug 17, 2023 | 12:57 PM
wymjym's Avatar
well my 2008 xk has factory 20" wheels and the spats
wj
Old Aug 17, 2023 | 01:04 PM
guy's Avatar
guy
07 xkr has them... I think it finishes off the wheel arch on her behind. It is ever so slight... when installed correctly @wymjym .
Old Aug 17, 2023 | 11:31 PM
kj07xk's Avatar
wj
Ok, so not limited to the XKR. 20” wheels appears to be the criteria.
Old Aug 18, 2023 | 08:03 AM
YES - I think wheel size was the determining factor.
My 2005 X100 and current 2014 X150 both had OE 20 inch wheels and spats. My 2006 XK with 19 inch wheels didn't have them. All of these are NA so 'R' versions wasn't the reason.
Old Aug 18, 2023 | 11:24 AM
earny's Avatar
Related to the question in the first post: of course the mud guards need to be placed rearwards (behind the wheel/tire), if it should make any sense.
Old Aug 18, 2023 | 02:49 PM
I should have read the question more carefully and/or looked at the photo more closely.
Old Aug 18, 2023 | 02:53 PM
wymjym's Avatar
thanks for the clarification...I kept scratching my head trying to determine how that placement made sense.
wj
Old Aug 18, 2023 | 04:43 PM
ABZXKR's Avatar
My car had them fitted incorrectly and this has caused serious corrosion where the securing steel clips have ben placed on the aluminium rear quarter panels.
If fitted correctly, the spats have rubber tabs that keep the clips away from the alloy body panel. There are no tabs where the clips sit against the plastic rear bumper.
Wrong position:
Correct position:
Old Aug 18, 2023 | 06:00 PM
I took this photo with the liner removed to illustrate the filler tube but it also shows the correct spat position and fixing clips.
Old Aug 18, 2023 | 07:05 PM
Tiepolo's Avatar
I have the 20" Senta wheels and no trace of these spats.
Old Aug 19, 2023 | 05:05 AM
I have the 20" Santa wheels and no trace of these spats.
Tiepolo,
(forgive the British humour - I have no intention or wish to offend. père Noël = Santa Claus and I couldn't resist asking the question .....)
Did you get the Santa wheels for Christmas?
Old Aug 19, 2023 | 07:48 AM
Tiepolo's Avatar
LOL
I wish I had such generous people around !
Originally Posted by GGG
Tiepolo,
Old Aug 23, 2023 | 08:33 PM
kenbowen's Avatar
I think that is probably true because the only time I have ever had them on a salvage that I bought were both on xkr's while none of the xk's had them.
steve_k_xk
Aug 17, 2023 07:41 AM
Han-S
Jun 16, 2023 09:15 AM
HoustonSalsaR
Sep 3, 2019 11:17 AM
Pie944
Jun 13, 2019 08:34 PM
Brake buster
Mar 4, 2008 06:34 PM
