REAR floor wet
Old Jan 17, 2020 | 02:46 PM
Blues1's Avatar
Default REAR floor wet
Drove my 07 XK yesterday, and noticed today, water coming from underneath and ran out of the garage. Fair amount of water. Traced it coming from the REAR passenger floorboard. Front passenger floor is dry, but rear floor is wet. Would this be the infamous duckbill issue? Seems all I've read about, is the passenger side being wet, assuming it's the front most are referring to. Would my rear be the same problem?
Old Jan 17, 2020 | 04:12 PM
dag82's Avatar
Had the same issue with my 07
We traced it to the molding Around the rear window above the trunk
rotted out needed to be replaced
check it out if cracked could be possibly
good luck
-dag
Old Jan 17, 2020 | 08:56 PM
Blues1's Avatar
Would the water have a place to hide for a couple of days before it comes out? Had not been drive in the rain for 2-3 days and it is garage kept. Forgot to mention it is a convertible. The top was replaced a couple of months ago, but this just showed up...
Old Jan 17, 2020 | 10:28 PM
WhiteXKR's Avatar
Got back to your new top installer, it is probably a leaking top.
Old Feb 14, 2020 | 09:29 AM
Blues1's Avatar
Happened again. It has been garage kept, no drive in the rain, no wash, no water from outside sources. There is no antifreeze in the water coming out so I assume it's condensation. I'm guessing it's the duckbill and water is travelling on top of the transmission and finding its way in at the bolts under the passenger seat. That is where the carpet is wet. After the last couple of drives, a fair amount of water exits the car from under the passenger seat area onto garage floor to where it puddles and runs all the way out of the garage. I don't want the carpet to mildew or start to smell.
Please, Any ideas or suggestions?!
Old Feb 14, 2020 | 05:18 PM
kj07xk's Avatar
Incontinence?
Old Feb 14, 2020 | 08:36 PM
Blues1's Avatar
Wish it was....then I'd know how to treat it..
Old Aug 5, 2023 | 05:34 AM
sidoogs's Avatar
Default Wet Rear Drivers Footwell
Did anyone ever get to the bottom of this issue? I have the same problem on my 2008 XKR convertible. The water only builds up after a long drive, at speed and collects in the void below the drivers seat. Once there’s enough water in there, the carpet start to soak it up. I am 100% convinced it’s A/C condensate, as the 2 occasions I have experienced it were after 1000 mile trips, in the dry.
Old Aug 9, 2023 | 07:28 AM
sidoogs's Avatar
Default Same Problem
did you ever get to the bottom of this?
Quantumleap67
Sep 25, 2022 09:16 AM
PeteK812
Aug 1, 2019 01:04 PM
CalicoCat
Nov 6, 2017 08:29 PM
foster6009
Jan 21, 2014 07:16 AM
TreVoRTasmin
Jun 22, 2013 10:34 AM
