Rear passenger side brake light
Old May 18, 2018 | 09:50 PM
robbing's Avatar
Default Rear passenger side brake light
2007 xk
My rear passenger side brake light has been giving me problems for the last few years. I get the message saying it's out but it's intermittent. The bulb isn't bad. Just wondering if this is a normal problem. I know on my wife's S Type the front blinkers had the same problem. I finally found out if you bend the connectors it stops happening. I'm hoping there is a simple fix for this as well.
Thanks in advance!
Old May 19, 2018 | 07:03 AM
Ranchero50's Avatar
Try it. The worst that happens is nothing.
Old May 19, 2018 | 09:41 AM
IanXF's Avatar
check that the contacts on the bottom of the bulb are'nt worn out I've re soldered them and it worked on my 08
Old May 19, 2018 | 10:05 AM
myexcursion's Avatar
Originally Posted by robbing
2007 xk
Thanks in advance!
same exact issue with my 07... sometimes it just stops working. I haven wife give it a quick slap and it works again. Probably something g to do with the contacts.
Old May 20, 2018 | 02:48 AM
1 of 19's Avatar
Mine right side also unionized on me and only worked part time. Clean and bend the contacts to make better contact. It took me two tries but has worked ever since going on 2 years.
NorCalDiesel
Sep 14, 2023 02:52 PM
chuckjag
Apr 16, 2017 09:45 AM
webshark
Aug 24, 2016 02:17 PM
jag79
Oct 19, 2010 09:43 PM
blipner
Aug 2, 2009 04:35 PM
