Rear Quarter Regulator Help!
Old Apr 29, 2025 | 05:38 PM
rjwood22's Avatar
Default Rear Quarter Regulator Help!
2008 XK convertible. I have removed the rear quarter regulators and replaced the spindle and cables. I have put the window glass back on as instructed in the shop manual. I need to re insert the regulator assembly into the vehicle.
My question is does anyone have a tip to make this a little smoother? I had a tough time getting them out with the glass removed and am concerned about trying to insert them with the glass attached.
Thanks for any help offered.
Old May 14, 2025 | 10:44 PM
badicedog's Avatar
Good evening, I too am in the same boat as you. What page number of the service manual did you find the replacement guide?
Old May 14, 2025 | 11:41 PM
kj07xk's Avatar
Window regulator removal starts on page 3358 of 4000 for the 4.2L manual. (At least in the copy I have.)
Old May 15, 2025 | 06:54 PM
rjwood22's Avatar
Default Update: I have replaced the regulators and have some tips.
The job is finished. Tips:
1. Do one side at a time. It is easier if you have something to look at if you get stuck.
2. After following the shop manual steps to remove the motor and regulator assembly-pull out all three from their holes and slide the top bolt forward. Slide the front of the gaskets on the door forward a small bit to make room for the reg assy. Rotate the entire assembly forward about 90 degrees. Work the window motor around the body and/or convertible struts. Pull it straight up.
3. When installing-DO NOT install seat belt assembly until after adjusting the three window bolts. You can’t reach the bottom one with the seat belt retractor installed.
4. Lube everything with lithium grease.
5. Learn new cuss words!😃
Jaunty
Sep 19, 2022 11:44 AM
beh2010
Jul 29, 2016 08:45 PM
lunagry
Oct 7, 2014 01:58 PM
jtg
Aug 27, 2012 12:11 PM
vettegood
Jan 30, 2012 02:16 PM
