Rear Subframe
Old Oct 9, 2024 | 12:51 PM
unklebuck's Avatar
Default Rear Subframe
Well after replacing all the front and rear control arms and calipers etc I bought in new bushings for the rear subframe as the fronts had rotted out, the rear bushings look ok but I am not taking chances.
I just got in new bushings front and rear for the rear subframe however, the frame has a lot of surface rust and corrosion. When checking it over and cleaning some of the rust off i found some holes and the frame just isnt that good.
Having looked on ebay all the second hand ones i found you could see the corrosion under a thick layer of black paint and they look like crap.
Found one on a breakers site thats near mint condition for a fraction of the price including vat and shipping so I am waiting for that to arrive.
Pics of one of the rotted bushes and the frame and the replacement dusty frame comingw ith the new front and rear bushes sat here waiting already.
will also have new subframe bolts.
One of the rotten rear subframe front bushes.you can see how rusty the sbframe is too.
Dusty replacement frame near mint will fit new bushes
Replacement frame new bushes already waiting to go in.
Old Oct 9, 2024 | 03:43 PM
Sean W's Avatar
Good times. Looking forward to seeing the final results.
Old Oct 11, 2024 | 10:35 AM
ChiefyO's Avatar
Where did you source that from ?
Old Oct 11, 2024 | 12:03 PM
unklebuck's Avatar
From an online breakers website. Only paid £379.20 this includes vat, shipping etc l, the part is coming from Spain.
I am replacing the subframe bolts, fitting new anti roll bar bushes along with new cover clamps, bolts, nuts. New diff seals, blasting the brace frame and powder coating it. I have already recently fitted all new rear arms etc and new calipers. So a few new crush washers for them and a couple of little things and all will be good. Having a week to get it all done.
Old Oct 11, 2024 | 02:31 PM
McJag222's Avatar
The rain in spain - probably why it's in good condition.
Old Oct 12, 2024 | 02:41 AM
ChiefyO's Avatar
Any chance of a website link ?
Old Oct 12, 2024 | 11:13 AM
Lothar52's Avatar
what is the part number for the rear subframe? Anyone know?
Old Oct 12, 2024 | 01:44 PM
unklebuck's Avatar
from the epc.
Old Oct 12, 2024 | 02:19 PM
jahummer's Avatar
When I replaced the subframe bushes with custom solid ones, I powder coated everything as well, though mine was entirely rust free, I didn’t anticipate ever removing it again.
Old Oct 12, 2024 | 03:31 PM
unklebuck's Avatar
I did look at other options for bushes however, I got a full set cheap and I only have a few weeks until the MOT here in the UK. So a straight swap out is the quickest option for now. When the new frame comes on I will give it a real good clean and give it a coat of por15 before fitting it.
Old Oct 12, 2024 | 10:45 PM
Lothar52's Avatar
Is the front subframe ever an issue. Ie the engine cradle?
Old Oct 13, 2024 | 05:14 AM
justinhill's Avatar
Yes, they rust like mad in the right climate.
Old Oct 16, 2024 | 11:15 AM
Cee Jay's Avatar
I am SO glad I live in a high desert and my car came from Dallas, there isn't a speck of rust on any of my steel bits.
Old Oct 21, 2024 | 10:55 AM
Lothar52's Avatar
what tool did you use to remove and replace those rear bushings? Interested to do this job as well after sand blasting and powder coating a new front and rear subframe. Do tell!!
Old Oct 21, 2024 | 11:16 AM
jahummer's Avatar
I used a press.
Old Oct 21, 2024 | 12:47 PM
unklebuck's Avatar
Frame arrived today while I was in work. It's practically mint condition, a couple of little surfaces with slight surface rust that will wire off clean with no pitting anywhere. Came with the rear wiring still attached and a level sensor. The bushes are in good condition however, I will be taking them out and fitting the new ones. Will update on how when I do them with lots of photos.
Old Oct 22, 2024 | 09:10 AM
jahummer's Avatar
It's shiny like it has been repainted...factory was matte.
Old Oct 22, 2024 | 10:01 AM
unklebuck's Avatar
No it's wet I had just washed the dust off it.
You can see the water in the bushes reflecting
Old Oct 27, 2024 | 12:34 PM
XKDreams's Avatar
Dang…what kind of road conditions causes rust like that? The only time I’ve ever seen that kind of rust was when we lived in Rochester, NY from 1976 through 1983. They used huge amounts of salt on the roads then. I had my beloved Datsun 240z turn into a pile of rust dust. But, I’ve not seen a car rust like that just from rain. We lived in the Portland, OR area for 7 years. We had constant rain for 9 months each year, but they didn’t salt roads, so cars didn’t rust.
My ‘15 XKR previously resided in the Naples, Fl area. Before buying it, I examined the undercarriage with it on a lift, and found no signs of rust anywhere.
Old Oct 27, 2024 | 02:43 PM
guy's Avatar
guy
Well... for starters, you're in San Diego and I'm in Ottawa. And unlike most, my car sees all the weather and conditions,
