Rear Subframe Removal - 2008 xkrs
Old Oct 24, 2025 | 09:45 AM
ericmcn's Avatar
Default Rear Subframe Removal - 2008 xkrs
How much of a faff is it to completely remove the rear subframe? next year I am thinking of taking this off to sandblast it and get it painted (probably with epoxy paint) and get a Quaife LSD fitted. I wont be taking it off but can do the painting - is it very labour intensive to take all this off? the font is pretty much done, apart from the parts touching the chassis. The rear has a cross member bolted to the subframe which doesnt look like its removable without dropping the exhaust.
Quaife LSD is about £1000, someone said these can mess up the traction control and stability control but I dont see how that is possible - they will just reduce the amount of time such features are engaged? My 2008 XKRS has the ability to completely disengage the traction control, I think only the RS vehicles can do this. Also on the to do list is get a 10% upper pulley done, thats it for me with upgrades. Fitting the LSD will be done by the Indy - way out of my skillset.
Cheers guys.
Old Oct 25, 2025 | 10:13 AM
guy's Avatar
guy
I have so many questions...
Title says 2008 XKRS... was there such a build?
I was under the impression that the XKRS came with the new style (electronically managed) of LSD...
Though, I much prefer the mechanical solution you mention with the Quaife.
Incidentally, many have opinions to which they have no practical experience... Or, they don't know how to drive a car with TC turned off. Either way, the Quaife LSD is EXCELLENT.
Cheers!
Old Oct 25, 2025 | 10:40 AM
ericmcn's Avatar
Cheers!
There was a 2008 XKR-S, I wouldnt have said it otherwise and its very good indeed - its surprising so many people dont know this exists - just 200 were made which probably explains the lack of knowledge.
Regarding TC, I believe only the RS models have the ability to completely disengage this, for track use or such - but open to correction.
I am trying to gauge how dfifficult its to remove the rear subframe of these and if anyone has it done?
Old Oct 25, 2025 | 03:02 PM
wymjym's Avatar
I just had to remove some of that light haze, hope you don't mind.
wj
Old Oct 25, 2025 | 03:17 PM
NBCat's Avatar
@ericmcn, here is a link to the X150 Workshop Manual:
https://www.dropbox.com/scl/fo/6h1c3...=f925ahf1&dl=0
Old Oct 25, 2025 | 03:22 PM
ericmcn's Avatar
I have seen it, I wanted real life experience - the Alternator for instance looks like a 2 hour job on the workshop manual and its anything but
Old Oct 26, 2025 | 10:36 AM
guy's Avatar
guy
Cool... I see now, it was a EU and UK only offering. I may have learned this once but forgot.
Incidentally, if you use the search function you will find a few posts about experience in removing the subframes.
unklebuck
May 2, 2026 02:19 PM
bullittandy
Nov 2, 2024 03:44 PM
MCW739
Sep 20, 2024 03:10 PM
wymjym
Aug 14, 2024 08:02 PM
Gino
Aug 21, 2021 01:18 PM
