Rear window Heater always on?
Old Feb 29, 2016 | 11:47 PM
White Bear's Avatar
Default Rear window Heater always on?
Every time I turn on my 2011 XK Coupe, the rear window heater comes on as well. It's no big deal to turn it off, but it's kind of annoying.
Has anyone else had this problem? Am I missing something obvious?
Regards,
Old Mar 1, 2016 | 04:38 AM
SeanU's Avatar
What is the outside temperature when you see it on?
Old Mar 1, 2016 | 06:41 AM
jagtoes's Avatar
It is temperature sensitive and will turn on automatically at a predetermined temp. I forgot at what temp but believe it is in the OM.
Old Mar 1, 2016 | 09:36 AM
mosesbotbol's Avatar
Best part is that particular temperature the climate control does not display correct. I forget what it was...
Old Mar 1, 2016 | 12:52 PM
amcdonal86's Avatar
I thought it also measures humidity. Not just temperature.
Old Mar 1, 2016 | 01:56 PM
jagtoes's Avatar
Heated screensThe front (
F
) and rear (
R
or
REAR
) screen heaters
may be switched on and
off in any mode,
including system off.
They will only operate
when the engine is running.
The front screen heater switches off
automatically after 6.5 minutes. The rear
screen and door mirror heaters switch off
automatically after 21 minutes.
The screen heaters can be manually deselected
using the buttons.
In cold ambient conditions, at the start of a
journey, the front and re
ar screen heaters will
switch on automatically for the timed period.
The rear heated screen will come on at
temperatures below -1°C (30°F) and the front
screen will come on below 5°C (41°F)
Old Mar 1, 2016 | 07:48 PM
White Bear's Avatar
Thank you guys, especially Jagtoes. I really thought I had a problem, turned out the problem was me. Yes it has been cold in Minnesota lately.
RTFM!
Regards,
reedmtn
Apr 13, 2016 11:12 AM
daro31
Apr 3, 2016 07:23 AM
kruh1982
Apr 1, 2016 03:38 PM
Johnken
Feb 19, 2016 01:19 PM
cacamp
Feb 11, 2016 08:22 PM
