Replace rear caliper
Old Mar 9, 2017 | 09:42 AM
8bit's Avatar
Default Replace rear caliper
One of my rear calipers is leaking fluid and requires replaced. Anyone done this? Did you have to do anything special with the parking brake system afterwards?
Old Mar 10, 2017 | 01:18 AM
JagV8's Avatar
Main thing is start with it not applied, and then keep key out of ignition. After fix, pump brake (so you'll have low EPB travel).
