Replacement for the awful OE Lug Nuts/Bolts?
Old Nov 1, 2016 | 07:08 PM
  #41
Box's Avatar
Box
Originally Posted by Cee Jay
Weird, the picture on the link shows Mag Style, but then it states:
SPECS: M12x1.50 Thread - One-Piece OEM Style - Conical 60 Degree Seat - 13/16” Hex
So, which is it?
Just a simple glance will tell you. They are mag style, with a 60 degree chamfer at it's base, just as it should. I've been doing vehicles for 40 years, spent a decade at one of the Big 3, and I do know a quality part when I have it. I purchased 4 different manufacturers lugs before I settled on the best one I could find, and that at 1/3 the cost of Gorilla. (and had a better chrome finish as well) They shine up right purdy... As always, never use an impact tool on chrome anything, and they'll last the life of the car.
Old Nov 2, 2016 | 12:14 PM
  #42
Cee Jay's Avatar
A CONICAL 60 DEGREE SEAT is much different than a chamfered insertion end on mag style. They messed up the description. How was I to know that they didn't mess up the ILLUSTRATION instead??? I guess I actually READ instead of relying on mere pictures.
Old Nov 2, 2016 | 02:30 PM
  #43
shemp's Avatar
These were only $18 shipped:
20pc OE Mag Style Lug Nuts with Washer | 12x1.5 | Toyota Lexus (Chrome Silver)) | eBay
They are chrome plated and seem to be decent quality. The base is a tad longer than the stock Jag but still about 1/8" less then the depth of the mag.
Old Nov 2, 2016 | 04:43 PM
  #44
AllblueACR's Avatar
was debating over these vs the Amazon ones for $33 and now that I know the plating is good, think i'll order these. Thanks
  #45
Cee Jay's Avatar
Well, huh............... I know eBay doesn't know everything, but this is simple:
Old Nov 2, 2016 | 04:49 PM
  #46
shemp's Avatar
If the XKR mag is thinner at the lug nut it may be an issue. I have stock XK mags. I can measure the base when I get home if you want.
Old Nov 2, 2016 | 05:07 PM
  #47
Cee Jay's Avatar
My current nuts are 10mm from washer base to end of mag shaft, or whatever it's called. I see that the new ones are 14mm from nut to end, but that disregards the unknown thickness of the washer. My stock washers are 2.5mm. It'd really suck to have nuts bottom out and not hold the wheel tight. I'll see if I can measure the depth of my stud holes, but if you could also shemp, that would be beneficial. All my tools are in my workshop garage, and I'm not near there. My wheels are the stock Nevis, so whatever the gap is would be great info. Of course since you already said they fit with the 1/8" clearance, all I'd have to know is if you also have Nevis wheels.
Old Nov 2, 2016 | 05:17 PM
  #48
AllblueACR's Avatar
and then figure out where my wheels fit into the equation...
Old Nov 2, 2016 | 05:45 PM
  #49
Sean W's Avatar
It's referred to as the "Shank" Cee Jay et al. So when looking (try shopping Jegs first) as it will usually provide Shank length and measure your stock to compare. If the new nut washers are thinner, revert to your OEM washers.
Old Nov 2, 2016 | 06:26 PM
  #50
Cee Jay's Avatar
They are captive washers, can't swap 'em. I suppose I could press them off and others on, but why? Could add extra washers also, but why buy new and then make them fit?
Old Nov 2, 2016 | 07:28 PM
  #51
Sean W's Avatar
didn't recall mine being captive and yes you can certainly buy new.
Old Nov 2, 2016 | 08:39 PM
  #52
shemp's Avatar
Ok. The washer is captive and the depth from the bottom of washer to end if shank is 12mm. Here are some pics of the finish. Looks ok but not the best. Gonna get coated with brake dust anyways . Also I don't know if I have Nevis wheels as I'm still a Jaguar novice but here's a pic of my filthy wheel with the lugs installed . Hope this helps.
Old Nov 3, 2016 | 05:43 AM
  #53
Box's Avatar
Box
I own them, and are on my vehicle. When I suggest them, it's not haphazardly. Have a great day.
Old Nov 3, 2016 | 01:27 PM
  #54
AllblueACR's Avatar
Thanks Shemp, Ceejay and Sean. Fleebay it is
Old Nov 3, 2016 | 01:34 PM
  #55
Cee Jay's Avatar
Sheesh, no reason to get all weirded-out.
All I said it that the description did not match the picture, which is true.
Old Nov 3, 2016 | 01:40 PM
  #56
Cee Jay's Avatar
Yeah, I THINK yours are the Vulcan wheels.
Thanks for checking, I'll order a set.
Old Nov 3, 2016 | 02:27 PM
  #57
shemp's Avatar
You guys probably already realize this but these are 21mm lugs so you'll need a new wrench. I bought one of these (and a few other members did too. See https://www.jaguarforums.com/forum/x...estion-170507/)
https://www.amazon.com/gp/product/B0...iglink21907-20
The design is solid but the bag is cheap. I wrapped a rag around the bag and pressed it right into the existing lug nut wrench storage slot.
Old Nov 3, 2016 | 02:41 PM
  #58
Sean W's Avatar
I may go this route. I'll look into in the offseason. Right now I just have a spare breaker bar and socket in the spare well.
https://www.amazon.com/dp/B00JFH6D1E...I1CHC1LZ2JH9BG
Old Nov 3, 2016 | 02:46 PM
  #59
shemp's Avatar
yea, I like that.
Old Nov 3, 2016 | 03:57 PM
  #60
Cee Jay's Avatar
I have a whole bunch of duplicate Craftsman tools, so I already have a 1/2" breaker bar and deep socket in the boot.
