replacement tires
Old Dec 8, 2017 | 08:59 AM
vacolorito's Avatar
Default replacement tires
what is the best recommendation for tire replacements on a 2014 XKR-S?
the car still has the original factory installed Pirelli tires.
i would like to "upgrade" if that's possible.
Old Dec 8, 2017 | 10:02 AM
CleverName's Avatar
This question was just addressed 3 days ago.
https://www.jaguarforums.com/forum/x...stions-193284/
Old Dec 8, 2017 | 10:47 AM
Tervuren's Avatar
I'm not sure what you mean by upgrade, but if you seek higher performance then go read as many reviews as you can.
Performance from a tire is a little complicated to judge as it is a matter of feel, feedback and grip levels.
Often the tire that has the highest peak grip, is more difficult to hold at that edge, which makes it easier to under-perform.
Personally I enjoy a tire with a crisp cut off from peak grip, where asking too much really hurts you. It is very satisfying to walk the edge with a tire like this, but when things go wrong you'd probably wish you had some other tire.
Old Dec 8, 2017 | 11:44 AM
mosesbotbol's Avatar
Sticking with stock will keep you from having to replace all four at once.
maxthrottle
Jul 5, 2021 02:24 AM
CCJagtyper
Sep 26, 2011 10:05 PM
deuceford
Nov 7, 2010 10:44 PM
compdude97
Aug 14, 2010 09:19 PM
jeiiomix
Feb 3, 2010 11:49 PM
