Replacing Fuel Injectors
Old Nov 22, 2023 | 02:06 PM
MonkeyJosh('09)'s Avatar
Default Replacing Fuel Injectors
To give some context, me and my friend (he's a mechanic) were able to figure out that my fuel injectors are leaking - it would leak even when the car is off, which would then result in a big cloud of smoke when I start my car after +1 hour of sitting with the fuel being burnt off My car is the 4.2L, has 96k miles and I've recently replaced my spark plugs and o2 sensors; I'll most likely change my coil packs as well. But my main question is what else should I replace while I have the supercharger and intake manifolds off? Any gaskets, hoses, or other preventative things items?
We're wanting to do this is in about a week or two so I have some time to order items. Thanks!
Old Nov 22, 2023 | 02:19 PM
McJag222's Avatar
On the 4.2 L, if that's what you have I would do the valley hoses that go from the back to the front.
Old Nov 23, 2023 | 05:36 AM
guy's Avatar
guy
If its all coming off anyways…
Supercharger fluid.
All coolant hoses
Heater hoses??
Throttle body cleaned??
NCJagman
Aug 6, 2020 12:15 PM
jobagadonuts
Sep 28, 2017 08:56 PM
sogood
Nov 26, 2016 08:55 AM
David Lawson
Mar 14, 2012 09:33 PM
