Hi All,
After a recent battery swap and an overly enthousiastic toddler pressing the memory buttons. The recliner function of my jag is no longer working. As many of these topics refer to the seat control module i have already investigated that, but it seems to still work fine for all the other functions on the 18 way seats.
To me it looks like the reclining part of the seat is somehow loose from the mechanical operating gears. meaning it is just hanging on the rear seats at this moment.
The dealer has quoted me with the installation of a complete new drivers seat.
Did anyone here already had an experience like this, and is it something that can be fixed without replacing the actual seat and just a the part that is broken?
Best,
NIEL
Best,
NIEL
wymjym
close
- Join DateOct 2016
- Locationnear Austin
Liked:1,238 Times in 639 Posts
Best,
NIEL
can you hear the motor when either decline or incline is attempted? If not, then the seat control needs to be recalibrated.Originally Posted by NIEL02
Hi All,After a recent battery swap and an overly enthousiastic toddler pressing the memory buttons. The recliner function of my jag is no longer working. As many of these topics refer to the seat control module i have already investigated that, but it seems to still work fine for all the other functions on the 18 way seats.
Best,
NIEL
WJ
guy
close
- Join DateApr 2008
- LocationOttawa, Ontario, Canada
Liked:1,679 Times in 1,174 Posts
with the motor running and gears clattering…. some entity other then a dealer may be able to fix it. I’d try an upholstery shop.
Quote:
WJ
Yes, i do hear the motor working, but it is not catching the mechanism to adjust the seatOriginally Posted by wymjym
can you hear the motor when either decline or incline is attempted? If not, then the seat control needs to be recalibrated.WJ
wymjym
close
- Join DateOct 2016
Quote:
too bad!Originally Posted by NIEL02
is the lean back fully reclined?
wj
The magic words. Battery replacement. Seat back no longer working.= Repair by internal computer only. You need to go into the computing system with the SDD to re-engage the seat. Dealer or hacker.
kj07xk
close
- Join DateJan 2015
- LocationNaperville, Illinois USA
Liked:2,589 Times in 1,701 Posts
Quote:
If the seat back is truly disengaged from the motor mechanism, can you lift the seat back by hand? How far can you raise it by hand? Since the other functions are working, can you move the seat as far forward as it will go, and peek underneath the seat (from the rear), yeah, you will have to contort yourself. Look and feel for anything loose. Originally Posted by NIEL02
Yeah, maybe something broke, or got stripped, but then maybe some fastener came loose and fell out (feel around on the floor under the seat too).
You may end up taking the seat out, so you can examine it more thoroughly. Even getting some wire and making yourself an extension for the seat wiring, so you can run it while out of the car and observe to see what’s going on.
wj
Yes. It is fully reclined. Without using the handle to normally access the backseat I can now fully recline and move the seat towards the steering wheel.Originally Posted by wymjym
too bad!is the lean back fully reclined?
wj
Will have to go and take the seat out and carefully undo the upholstery to see what's going on then
wymjym
close
- Join DateOct 2016
Given the lead up to your seat problem I strongly believe the issue is electronic not mechanical.
But that is an educated guess.
Many programmers can run the seat through a recalibration, some are quite inexpensive.
My NT530 handles this and much more.
wj
wj
SNAPCHAT
close
- Join DateJul 2022
- LocationIdaho
Liked:46 Times in 28 Posts
wj
Where do you think I should start if I am in this situation? Am in need of a calibration - changed battery. Is learning SDD way too complicated? Is there an alternative tool? People to contact?Originally Posted by wymjym
Given the lead up to your seat problem I strongly believe the issue is electronic not mechanical.But that is an educated guess.
wj
kj07xk
close
- Join DateJan 2015
Quote:
Umm, there was a suggestion right in the post you quoted, the Foxwell NT530.Originally Posted by SNAPCHAT
jahummer
close
- Join DateDec 2008
- LocationFlorida
Liked:2,582 Times in 1,621 Posts
Very common problem resovled via seat module reset. JLR SDD can do it as well as SOME third party scan tools. Takes just minutes to fix.
SNAPCHAT
close
- Join DateJul 2022
- LocationIdaho
Quote:
Lol, right, but its a matter of spending $150-200 for a Foxwell device thats barely different from what I have, or I am using the free and obtainable SDD software. And that is IF there isn't a way I can pay someone to just simply remote in and just do it for me. My car has data and the ability to be remoted into. Considering all options but definitely not going to just jump on your first suggestion.Originally Posted by kj07xk
guy
close
- Join DateApr 2008
Well, good luck. I am intruiged; a remote connection to an '07?! How?
With my positive relationship with one particular dealer, they have reprogramed the module pro bouno, while performing an oil change.
SNAPCHAT
close
- Join DateJul 2022
- LocationIdaho
I have the 12" tesla android screen installed - and it has a SIM card tray. Have an unlimited call/text/data line setup on it for like $25/m. Since the screen is an android tablet programmed into a car stereo, we can install apps like Netflix and Youtube among a billion other things (teamviewer, VNC, any remote program) to use while driving down the road. The car technically has a phone number lol.Originally Posted by guy
Well, good luck. I am intruiged; a remote connection to an '07?! How?With my positive relationship with one particular dealer, they have reprogramed the module pro bouno, while performing an oil change.
jahummer
close
- Join DateDec 2008
- LocationFlorida
Quote:
Right, but it’s not going to reprogram your seat module. That must be done via OBD either with JLR diagnostics or a suitable scan tool. Originally Posted by SNAPCHAT
guy
close
- Join DateApr 2008
With a gateway interface to the ODBII port?? Or r/w access to all modules on the ICANN network? I've not heard of this.
jahummer
close
- Join DateDec 2008
- LocationFlorida
Quote:
Is there an Android diagnostics app which supports Jag module calibration? Even if so, the aftermarket “Tesla” screen’s irrelevant unless the poster lacks a smart phone which’s unlikely. You don’t need remote tunneling to reset the seat module, it’s quite straightforward with the proper tool. Originally Posted by guy
Cee Jay
close
- Join DateApr 2013
- LocationKaysville, Utah, US
Liked:6,401 Times in 3,741 Posts
Actual TESLAS can do this remote-in thing, but the 'Tesla' screen in these cases are only nicknamed "Tesla-Style" because of the very basic appearance. A large screen with a lot of stuff on it.
SNAPCHAT
close
- Join DateJul 2022
- LocationIdaho
Quote:
Laptop using SIM data -> cord -> OBD port -> remote program -> seat calibrationOriginally Posted by jahummer
Quote:
It is no different than me fiddling with my own car. Except that I have someone remoted into the computer doing anything necessary - in the instance we are using SDD or some other program. It is no different than paying a tuning shop money to literally tune your car from 1,000+ miles away. As long as there is a tool that they can use to fiddle with the electronics, anything in this life is remote-able.Originally Posted by guy
Quote:
As per the first thing I asked, not knowing if it was a foxwell task or an SDD task - if it is SDD it can be remoted. If it is a foxwell task, remoting wasn't even going to be considered.Originally Posted by jahummer
I bring up the Tesla screen, because it actually is a computer. It is not the same piece of machinery (stereo) that came stock in these cars. The stock stereoes are terrible. Literally god awful. It being an Android, and me being an IT guy, I promise it can do more than anyone will ever realize lol. I can drive down the highway and be remoted into my computer at home and daytrade.
