Seat Reclining issues
Old Jun 13, 2016 | 05:33 PM
sov211's Avatar
I wonder if I have misunderstood: you drive your car rarely; you had a seat calibration problem caused by low battery voltage, an airbag light, and "many errors" related to low voltage...but you will not use your CTEK daily?
One of us is confused. Is it me?
Old Jun 13, 2016 | 10:20 PM
synperkaya's Avatar
Thumbs up my fault
its my fault i meant that i will be using my ctek on a daily basis to avoid paying the dealer hourly rates on resetting the codes again. thanks for all the help
al
Old Jun 14, 2016 | 12:25 AM
sov211's Avatar
Ah! I misunderstood you. A very good decision, I think. My XK has been on the CTEK for the last 4 years when not in use, and I have had no a single problem with the car, either electrical or otherwise. I can only attribute the electrical integrity to the CTEK, of course. But to even things up, tonight my wife left the lights on in her X-Type and ran the battery down. An hour on a quick charger and all is well but I will put it on the CTEK tomorrow just to make sure it is at full strength.
Old Jun 15, 2016 | 12:54 PM
SickRob's Avatar
Originally Posted by synperkaya
There was solution...The seat reclining issue was due to the seat calibration error. The main culprit according to the jaguar dealer, was the low voltage. according to the mechanic, there were many errors related to voltage and caused the seat to not calibrate. I also had an airbag light that would not clear, and they were able to clear the light. Even though my battery is less than a year old, I am not going to leave my Ctek connect daily. This was all repaired within an hours rate.
thanks to all the help in regarding to this problem...
AH HA!! I have the same problem, and I just had a new battery installed. So off to the dealer I go armed with knowledge. thanks.
Old Jun 16, 2016 | 08:51 AM
synperkaya's Avatar
Thumbs up always glad to help
Awesome, I know I did a lot of research on this issue from this forum, in fact when I met the Jaguar mechanic, the first thing I instructed him was about the seat calibration portion, of which he immediately agreed and that he has seen this issue before with other jaguars...good luck..
Old Jun 17, 2016 | 10:39 AM
SickRob's Avatar
Just got mine recalibrated by the dealer this morning. When I told the tech it was a recalibration issue due to battery replacement he dismissed that idea. He assumed I tried to jump the car and did some electrical damage; which I had not done. A quick trip to the computer confirmed your advice on causation, and he reset it. All's well that ends well.
Old Jun 20, 2016 | 10:22 AM
synperkaya's Avatar
Awesome...I am glad I was able to contribute to this forum..
al
MotorMan
Jun 7, 2016 10:28 PM
Jaguar Forums Editor
Jaguarforums Merchandise
Apr 24, 2016 05:57 PM
Saspc
Apr 23, 2016 03:03 AM
xjrjag
Apr 14, 2016 11:57 AM
skubeedoo
Apr 12, 2016 04:30 AM
