Service Soon Light
Old Dec 26, 2021 | 05:59 PM
JDog's Avatar
Default Service Soon Light
Hello Everyone:
I am getting a " Service Soon" light that comes on then off when starting. How do I know what service needs to be done without a scanner? I read how to reset the light.
Joe
Old Dec 26, 2021 | 06:03 PM
ralphwg's Avatar
These car require an annual service as a minimum. Look in your owner's manual. If you don't have one, you can download one from the stickies at the top of this thread. Most XK owners on this Forum change the oil in the cars every 3 to 5k miles.
Old Dec 26, 2021 | 09:17 PM
lear60man's Avatar
  • With the ignition off, press and hold the FOG lamp switch
  • Press the START/STOP button once without pressing the brake pedal
  • Release the FOG lamp switch
  • Press and hold the TRIP button and the FOG lamp switch
  • Keep hold both buttons for 10 seconds or until SERVICE MODE RESET appears on the display
  • Release both buttons and turn off the ignition
  • Start the engine to confirm the service light has been reset
  • Yes the picture was lifted from an XF ...but its the same procedure to reset the service reminder.
Old Dec 26, 2021 | 11:37 PM
Speedmaster's Avatar
Thanks for this. I was wondering how to reset mine.
Old Dec 27, 2021 | 03:24 AM
TIMING is critical or the reset procedure will fail. Here's the sequence as shown in SDD:
SDD is NOT required to do a reset.
Old Dec 27, 2021 | 08:51 AM
britannia's Avatar
JDOG,
Three things ALL modern Jaguars require is: a service manual, a battery maintainer, and a code reader!
In the OLD days you needed to carry a spare SU fuel pump too! I even used to show it to the Jag on occasions! these Cats are very smart!!!
Don't be so cheap! You will regret it............
Happy New Year everybody, from Seattle in the snow!
Cheers Adrian
Old Dec 27, 2021 | 10:20 AM
lear60man's Avatar
Thanks Grahm. And you are correct, it has to be done in 3 seconds. It took me a few tries to get it right after an oil change on the wifes KX a few months ago. But muscle memory prevailed when I had to do it again two weeks ago on mine.
Old Dec 27, 2021 | 07:20 PM
jagtoes's Avatar
Originally Posted by britannia
JDOG,
Cheers Adrian
You forgot the check book.
Old Dec 30, 2021 | 08:28 PM
panthera999's Avatar
..and tapdance the tarantella around the room. Maybe watching the Witcher too much, but it reads like someone casting a spell. Eye of newt, toe of frog ...Try reading it outloud. (grin)
JAL
Jul 19, 2020 10:21 PM
cpq100
May 5, 2020 04:18 PM
guppydriver
XE ( X760 )
16
Aug 17, 2019 10:59 AM
Dan Wink
May 2, 2019 03:35 PM
JagGate
Jan 18, 2018 02:57 PM
