Shredded Serpentine Belt
Hello out there, I was enjoying a beautiful day out here in the SF Bay Area with the top down when all of a sudden I feel a loss of power steering followed by a battery not charging light. I pulled over & could see parts of the serpentine belt shredded. Luckily I was a block away from an Indy shop & caught him b4 closing. He will check it out for me in the morning. 2010 5.0 XKR on water pump #3. Although this time it didnt seem like the water pump. Could be an alignment issue if the pullys from the last pump swap or who the heck knows. Ill update you as I find out.
If it shredded, the belt was on its way out, an idler pulley seized, or an ancillary pulley did it. Since there is no belt, turning all of the pulleys should reveal something. At least it was a nice day! It's worse when the weather is against you.
So far Ive been told the tensioner failed but theres also some oil leaking in the area that they are trying to figure out. The tensioner is 1-2 days wait so dont know if they can figure out the oil leak until the tensioner is installed. Im going to stop at the shop in a few hours & have a look myself.
Wow a 2-3 day wait in San Fran are you buying OEM from a dealer?
I live in a rural part of England and had a tensioner pattern part fitted purchased from a local motor factors, worked fine for 50k miles, the belt for my X100 was a Dayco IIRC, but always keep a spare for any car I've owned for the last 20yrs.
My mechanic had to compress the tensioner with scissor jack and secure with the largest cable tie he could find, fitted and he cut the cable tie and it sprung into place
All in all took him 30 mins to fit...and that was with the bumper in-situ.
Its pretty hilarious that it takes that long. I havent come across a part I needed on the two XKRs Ive owned that has been in stock. Usually its 24hrs. Not sure why 2-3 days this time. I briefly looked online today & couldnt find anything that would be much quicker. At this point im more concerned what the oil leak is, seems like its engine oil but wont know till a belt is back on & everything is operational on the pulley/belt side of things.
rocklandjag
Feb 23, 2015 06:15 PM
02intrigue
Oct 25, 2007 08:46 PM
