Slow Cranking XK 5.0
Old Jan 19, 2021 | 08:54 AM
guy's Avatar
guy
But I also give the battery a helping hand. When the temperature gets near freezing, I plug in the inline heater. A warm engine starts easier than a cold one.
Old Jan 19, 2021 | 10:03 AM
MarkyUK's Avatar
Originally Posted by Wizz
Quick update before a business trip - checked this morning battery was at 12.5v started ok (very slight slow crank for a second) went for a 6 mile drive parked stop and then restarted all ok drove back home tested voltage and was 12.4v. I have a silver Bosch battery
You didn't say how many miles and what electrics were running?
Also Stuart is correct re hot/cold but he may not appreciate that VERY high temps are unheard of in the UK (despite me saying earlier that over 75f was rare in the UK) whereas some US states see regular 100f temps, so I don't believe that train f thought holds here.
Since your battery is under warranty change it out, since it's at n cost to you
My 4yr old Bosch is running at 12.9v tested across the terminals,,, but your CTEK supposedly already ordered should be with you soon
Old Jan 21, 2021 | 01:50 PM
Hadakajime's Avatar
I hope you carry a jump starter with you when you go out...
Old Jan 24, 2021 | 12:17 PM
tampamark's Avatar
When starting my 09 XK it initially when cold cranks slowly for the first second or two then cranks normally and starts. However sometimes when hot it cranks over really slowly as if the battery is flat (and slow enough to make me think its not going to start) and then starts this happened earlier today. I drove about 10 miles, turned engine off for about 10 minutes then pressed the starter and it cranked over really slowly and started, i let it run for about 15 seconds then turned off again and it then started normally. I replaced the battery about 10 months ago so I know the battery is OK plus I am not getting not getting any on screen low battery warning messages.
Any feedback will be appreciated and thanks for reading
Chris
The battery may be fine and you just have the very common slow battery drain. I have a battery about the same age, when it gets a bit tired I throw it on for an overnight trickle maintainer. I try to put it on at least once a week as a preventative action, but there are times I may go a month and the car will tell me it is thirsty for electricity by choking at startup a bit. If it has a slow turnover I shut it off, stick it on the maintainer, and take the SUV instead. After being fully green on the maintainer it is perfect for a period of time until it is no longer perfect.
My slow drain is the consequence of our unfavorable driving profile, very short trips locally that don't replenish the battery on it's own.
Old Jan 26, 2021 | 01:09 AM
Barry Leftwich's Avatar
Chris
might be your alternator about to go.I had to get mine replaced in my 2007 XKR that i no longer have at around 50,000 miles in the summer of 2016
Pat Stclaire
Mar 6, 2024 05:32 AM
jackson999
May 2, 2023 12:44 PM
newman
Feb 15, 2020 04:29 PM
zealjag
Jul 31, 2019 11:36 PM
XJJags
Jun 8, 2015 09:15 AM
