Small hose expansion tank to metal hoses.
Old Oct 16, 2024 | 05:15 AM
Cliffords's Avatar
Default Small hose expansion tank to metal hoses.
Had a search but can't find it . There is a small hose from the expansion tank down to the metal hoses. Held with a clip at each end . I know it's a known weak spot and mine does have a large split in it . Not leaking yet surprisingly, although I am out later today so it's bound to . It's about 6 inches long total.
I have read it's not a part to buy individually, but others must have a solution. It may be different size at each end , I think I have read?
Any experience and solutions welcome, thank you.
2007 XK
Old Oct 16, 2024 | 01:53 PM
Cee Jay's Avatar
A tighter clamp on the bottom with a hose that fits best you can find? Small diameter lines carry little actual pressure since such a small area.
Old Oct 16, 2024 | 03:25 PM
Tracee's Avatar
Dealer says you can't buy the rubber hose alone, you have to buy the entire assembly of metal piping. Thats nutz - I just fabricated my own hose. Make sure that the spigot from the tank isn't the culprit - that's a weak point and the fluid runs downward, maybe looking like that the hose is the culprit.
Old Oct 16, 2024 | 04:35 PM
Cliffords's Avatar
It's not actually leaking right now , but it has a split in in , see first pic.
I will experiment with some hoses over the next few days , perhaps one hose of the spigot size with a smaller hose pushed in for the lower connection. Made up with a metal sleeve for the join. Easy access but a short run for a fiddly hose .
It must be a common fail now , but there does not seem to be anything already made up,available here in the UK.
Old Oct 17, 2024 | 09:05 PM
DeeDoubleYou's Avatar
Default Quick Hiaw Fix
What is the OD of the metal portion of the hose that has the crease in it? Can you find a rubber hose which you could slip over it, like a cuff, at least temporarily?
Last edited by DeeDoubleYou; Oct 17, 2024 at 09:17 PM. Reason: Added information and corrected spelling
max224
Apr 16, 2022 07:44 PM
Andy W Nichols
Aug 22, 2020 12:15 PM
Plugger22
Jul 19, 2018 09:38 AM
chrisc923
May 20, 2014 02:02 AM
Plant
Jun 18, 2013 01:08 AM
