Smell antifreeze in exhaust
Old Jul 17, 2019 | 05:27 AM
Tonyqt's Avatar
Default Smell antifreeze in exhaust
2010 xkr with 72,000 miles. Im thinking head gasket. Just a little white smoke at start up but can definitely smell it up close. Once warmed up no white smoke. How screwed am I?
Old Jul 17, 2019 | 07:01 AM
jagtoes's Avatar
How is the level in the coolant tank. Also what is the level of the oil on the e-dipstick. Is it over full. Some white smoke is normal during start/warm up . What about your water temp. after warmed up. Head gaskets just don't normally go bad unless you overheated the engine. The smell can be from a leak somewhere other that a head gasket. Don't over think the concern.
Old Jul 17, 2019 | 11:42 AM
Ranchero50's Avatar
Also, if that goofy plastic coolant manifold on the firewall leaks it'll most likely drip on the cats. Chances are something could be seeping and you are noticing it upon startup. White exhaust could be condensation with a little stink mixed in. Monitor the coolant level to get an idea of your loss.
Old Jul 17, 2019 | 06:42 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Investigate First, Panic Last.
Jack
Old Jul 19, 2019 | 03:24 AM
JonWat's Avatar
Test the coolant for exhaust gasses which will be present if the head gasket is leaking.
Old Jan 20, 2022 | 01:46 PM
The_Ikon's Avatar
Hey what was the verdict? I’m interested….. don’t leave us hanging you can help another member out with the solution.
Old Jan 20, 2022 | 03:07 PM
Cee Jay's Avatar
The OP, Tonyqt, hasn't been on the forum for 2-1/2 years. This original post was his last ever.
Old Jan 20, 2022 | 08:35 PM
The_Ikon's Avatar
Kool! I hate when they do that…. As least show appreciation for the help and follow up!😡
phanc60844
Jul 30, 2016 12:50 PM
Evan Trinh
Jan 22, 2016 11:28 PM
larueb
Mar 12, 2015 09:23 AM
badmojo
Sep 11, 2009 11:45 PM
badmojo
20
Aug 7, 2007 01:40 PM
