Speedpack rear bumper extension - what are the options?
Old Nov 4, 2020 | 12:51 PM
tmich's Avatar
Default Speedpack rear bumper extension - what are the options?
Hi,
I would like to make my XKR look like a speed pack. The only missing part is a rear bumper.
Found this one a forum:
What are my options:
- salvage car as a donor of a used bumper
- OEM part, which is horribly expensive
Does anyone know how is manufacturing them? Chris from a Mina Gallery?
Old Nov 4, 2020 | 05:59 PM
jahummer's Avatar
It is not an entire new bumper, in fact the rear bumper has been the same part on all iterations of the X150. The speed pack add-on is the part you see in white and at one point Mina did offer them. The difference between OEM and aftermarket is the material used. OEM is flexible urethane like the OEM bumper and aftermarket will be rigid FRP or GRP. The problem with rigid add-ons is they are very porous and can be tricky to fit properly and are typically best left to a specialist to prep, seal, paint and fit.
Old Nov 5, 2020 | 02:19 AM
steve_k_xk's Avatar
Check out Cotswold I got my diamond stitch interior from them, they do genuine oem and or aftermarket components just depends on one's budget
https://www.cotswoldautoparts.co.uk/
Old Nov 5, 2020 | 02:50 AM
tmich's Avatar
I will get in touch with them. Good hint, thanks.
Old Nov 5, 2020 | 10:10 AM
jahummer's Avatar
That's also where I purchased the R-S bits for the rear bumper and carbon fibre boot plinth at massive savings, Steve always seems to have quite the inventory. Reminds me of another UK supplier of genuine McLaren parts at huge savings over factory direct, Hybrid Performance LTD
Old Nov 5, 2020 | 10:14 AM
tmich's Avatar
Unfortunately they don't have it. Only XKRS replica, which does not match with speed pack sills (they are wider than XKRS sills).
I will check with the other ones, that you mentioned.
AlexSaltLife
Jan 23, 2023 10:41 AM
quicksilvr20
Nov 20, 2015 09:10 PM
stelious
Apr 22, 2014 06:19 PM
AlbBolivar
XJ40 ( XJ81 )
Jun 21, 2013 06:02 PM
GhostriderXKR08
Feb 21, 2011 01:42 PM
