Stock fuel pump ok?
Old Nov 7, 2020 | 02:24 PM
kazi's Avatar
Default Stock fuel pump ok?
Some guys were going back and forth in a thread about weather you need a bigger fuel pump for 500+ HP. Some guys said stock was fine past 500. Others said IAT ran cooler with 255lph pump. Any thoughts? I'm at 100,000, don't know what previous owner did. Should I replace it or if it ain't broke don't fix it with this one?
Old Nov 7, 2020 | 02:55 PM
Cee Jay's Avatar
Maybe instead of a different fuel pump, just rerun some larger lines with less restriction?
Old Nov 7, 2020 | 03:45 PM
kazi's Avatar
Thats a good cheap mod. I heard about a booster pump? Gonna look into that. So not a sheduled part to replace? It just seems sketchy to wait till it fails.
Old Nov 7, 2020 | 04:48 PM
Cee Jay's Avatar
Way I've heard, a booster pump will mess up with the stock pump and ECU, as the pump is a variable flow unit which is controlled BY the ECU. If that is indeed correct, I'd think that the only possible improvements would be had by optimizing what's already there and leaving the tricky bits alone. That's why I thought of the New Line. One straight length of 1/2" stainless braided teflon with AN fittings is what I did to my P/S Mustang, and it's been completely reliable and always steady. One long, continuous flow with zero obstructions from Start to Finish can only help. Half-inch MAY be a bit more than our cars NEED, but why not?
Old Nov 7, 2020 | 05:25 PM
AlexJag's Avatar
Sponsor
Take it from someone who actually is running 500hp plus. NO you should not be concerned with your duel pump.
sc pump will help with iat some. I see your near San Diego , we can do thermostat upgrade, sc pump upgrade, ecu tune , lower temp sparks plugs and you will be good !
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Nov 7, 2020 | 05:51 PM
kazi's Avatar
Alex its me Cary! lol. The reason i'm at 500hp is because of you, so I'll trust what your saying about the pump.
afterburner1
Jun 6, 2020 04:37 PM
plums
General Tech Help
Jan 17, 2016 02:28 AM
Toybreaker
Nov 17, 2015 03:22 AM
mustangtyson
Feb 15, 2015 06:00 PM
gunnerman
XJ40 ( XJ81 )
Jul 12, 2010 12:20 AM
