Supercharger Maintenance
Old Jun 25, 2015 | 02:53 PM
Chadly's Avatar
Default Supercharger Maintenance
I have searched but cant find anything. Is there maintenance that needs performed on the supercharger? (2007 XKR). Oil, coolant, etc.?
Old Jun 25, 2015 | 04:55 PM
Ngarara's Avatar
There's no cooling system for the SC - there's air-water intercoolers beside it, but they're part of the main cooling system (separate but connected).
There is lubrication for the SC; I think it's "sealed for life" according to Jaguar, but one of the Eaton resellers says (about the TVS 1900 unit used in the 5.0) "Only requires an oil change every 80,000-120,000 miles". It's a bit like the gearbox: it officially needs no attention, but the component manufacturer says it will benefit from servicing at higher mileages. There's a filler plug in the TVS rear bearing plate - the 4.2 manual doesn't talk about a filler in the M112 SC, it just says "The supercharger has a sealed-for-life internal lubrication system". I've seen people talking about changing the M112 oil online, so it must be do-able.
Old Jun 25, 2015 | 05:22 PM
DGL's Avatar
DGL
Originally Posted by Ngarara
There's no cooling system for the SC - there's an air-water intercooler underneath it, but that's part of the main cooling system.
Ross, you're a great asset to this forum.
Old Jun 25, 2015 | 06:34 PM
Ngarara's Avatar
Weeeellll - I've still had to correct that post about 5 times, but thanks
Old Jun 25, 2015 | 06:41 PM
Cambo's Avatar
Oil change on the M112 is possible, lots of threads in the XJ sections about it.
There's a filler plug on the front of the housing.
In fact in the early days there was a scheduled oil change in the Jaguar documents.
Many of us have changed the oil in the SC. You need a syringe to suck out the old oil, there are kits on eBay for this from Powerhouse in the UK.
Old Jun 25, 2015 | 08:03 PM
plums's Avatar
GM uses Eaton superchargers in a number of vehicles.
They don't claim sealed for life. Their service interval is 30K miles.
Old Jun 26, 2015 | 12:17 PM
Chadly's Avatar
Thank you all for the info.
I guess "If it aint broke..."
Old Jun 26, 2015 | 01:38 PM
Ngarara's Avatar
Well, the thing about preventative maintenance is that you're supposed to do it before it's broke.
I'll certainly be getting my transmission fluid, filter & cable gaiter replaced if I get to 60k miles. I doubt I'll see 80k, so the SC lube change isn't something I'm likely to worry about.
Old Jun 26, 2015 | 02:08 PM
Chadly's Avatar
Hah! Yes preventive maintenance, but not something I need to do right away is what I meant.
MrWhite
19
Jun 14, 2022 07:49 PM
wonderwire
Oct 4, 2015 05:41 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
