Suspension Actuator Weather Pack Connector
Old Jul 3, 2017 | 12:23 PM
J5hort's Avatar
Default Suspension Actuator Weather Pack Connector
Hi All,
Pulled a wheel to detail a bit and noticed a small actuator on the suspension. There was a weather pack connector that looked like it was crushed and 2 of 3 wires were disconnected. I'm wondering what I am missing with this not connected and if it is harmful to drive. Loose wires have now been taped and I am in search of the proper connector that I can replace the damaged one with.
Any ideas/suggestions?
Old Jul 3, 2017 | 12:27 PM
Cee Jay's Avatar
YOU'RE GONNA DIEEEEEEE!!!!!
Wow, with something that obscure, maybe a breaker's yard would be the best place to find a replacement. Other than that worthless bit of advice, I'm out of ideas. Maybe I shouldn't even have posted.......
Old Jul 3, 2017 | 12:55 PM
J5hort's Avatar
Getting a Welcome to the Jungle - Axel Rose vibe from that last response. Hope that is what you were going for. I appreciate you response as you have a better suggestion that anything that I have in mind. Originally thought breaker's yard was some kind of retail store..then realized you may be a junk yard.
Certainly a good option...I really just need the pigtail. I am assuming the actuator itself is fine, but may need to test that also.
Old Jul 3, 2017 | 01:12 PM
Cee Jay's Avatar
Originally Posted by J5hort
..... Originally thought breaker's yard was some kind of retail store..then realized you may be a junk yard.
Yeah, I was attempting to be British with the Breaker's Yard.
I did also assume that you just need the connector and a bit of wire on both sides. No sense to replace a sensor that functions fine. That's why I suggested the salvage option, cheapest fix, and probably nearly the easiest as it'd only require six splices. Now, what other models would use this connector? Maybe even some Ford models..... Lincoln LS perhaps? I sold mine a few years ago so I'm no help on that end.
