Suspension questions
Old Apr 10, 2024 | 04:36 PM
Jeff1172's Avatar
Default Suspension questions
78 year old Healey/MG lover graduated to a gentlemen’s sports car, an 08 xk convertable. Still like to fix things so just a simple question for someone who has been there.
Front upper control arm needs to be replaced, fairly obvious. Also the shock tower is covered with bits of foam. Car is a driver so what parts on hand to finish in a day. Question - should i purchase both a mount and an insulator? Will i need a spring compressor?
using this forum i found a control arm by Motorcraft,mcsoe38, for 20% of dealer price. Hope that works out.
Any help on other parts source and type will be appreciated.
Aloha,
jeff
Old Apr 10, 2024 | 05:58 PM
kj07xk's Avatar
Post a picture of the ‘bits of foam’, not sure where exactly you’re seeing them.
If you do decide to replace the isolator, and you’re talking about the spring compressors you can borrow from an auto parts store, you’ll need two sets (pairs). A single set will not compress the spring far enough. Compress with the first set as far as you can, then use the second set on the now exposed gaps in the spring at the top and bottom to do additional compression.
(Compression is done after you remove the strut from the car. No need to compress on the car.)
Old Apr 10, 2024 | 06:31 PM
Cee Jay's Avatar
Originally Posted by kj07xk
Post a picture of the ‘bits of foam’, not sure where exactly you’re seeing them..................)
Awhile ago some new member posted pictures of "foam" on top of the strut towers. It was actually deteriorated isolator material.
Old Apr 10, 2024 | 07:04 PM
trkyam's Avatar
Hey Jeff, I'm also an XK owner in Honolulu,
The upper control arms are shared parts with many other cars and can be had for under $100
The spring isolators AKA upper strut mounts are shared with the XJ and XJR part # (C2D51875, C2P3209, C2P22948)
I also need to change these exact parts, do you need a hand?
Amazon Amazon
Amazon Amazon
Old Apr 10, 2024 | 07:46 PM
Jeff1172's Avatar
Old Apr 10, 2024 | 07:49 PM
Jeff1172's Avatar
Sounds good. Let’s talk. Can I leave a phone number here?
Old Apr 10, 2024 | 07:53 PM
kj07xk's Avatar
Originally Posted by Jeff1172
Well that looks gross. As Cee Jay stated above, your isolators probably deteriorated.
Old Apr 10, 2024 | 07:54 PM
Jeff1172's Avatar
Picture posted! Not too tech smart. Hope you see it. Thanks Kj.
J
Old Apr 15, 2024 | 05:02 PM
fritzthecat's Avatar
You need the isolator and the mount. I did mine a couple of months ago. I have pictures just been lazy about writing the whole project up and posting it. You will also need a T60 torx bit.
Old Apr 15, 2024 | 07:46 PM
panthera999's Avatar
Jeff,
Your isolators are rotted. $80 each from Jag. $10 each from china. To replace the isolators and mounts, a pro needs to take the strut assembly apart. Don't do this if you've never done it before. The spring can kill you as it releases. Follow the repair manual, or hire someone.
Panthera
Old Apr 15, 2024 | 07:49 PM
Jeff1172's Avatar
Good advise. Thank you very much
jeff
Old Apr 15, 2024 | 09:00 PM
McJag222's Avatar
Ay Crumba
Old Apr 16, 2024 | 06:54 PM
Just posted the repair I did. Here:
Front Strut Leak? - Page 2 - Jaguar Forums - Jaguar Enthusiasts Forum
Paws4thought
Apr 22, 2024 07:21 AM
jaginaustin
Dec 22, 2022 09:52 PM
Marc Voorhees
Jun 12, 2020 09:02 AM
vdpnyc
Jul 30, 2016 08:49 PM
cppeabody
Oct 27, 2014 09:48 AM
