Switch to XKR-S tune on ECU using SDD?
Old Feb 21, 2023 | 07:49 PM
  #41
steve_k_xk's Avatar
Originally Posted by OzXFR
Yep.
I had the XKR-S tune flashed onto my 2010 XFR a few years ago, using SDD.
The tune file was NOT already on the PCM/ECU but had to be flashed onto it over the top of the stock tune.
And it didn't "stick" until I had an H-pipe installed in the exhaust system in place of the front muffler.
I know some of the Quicksilver products come with H-pipe however It goes against the grain of pretty much everyone on here as we go x-pipe ... I'm intrigued what made you go H-pipe instead ??.
Old Feb 21, 2023 | 08:26 PM
  #42
OzXFR's Avatar
I was going to go with an X-pipe then my exhaust specialist (who really knows his stuff, sadly retired now) recommended I go with an H-pipe instead. He said it would have the same effect on the tune but a "nicer" noise.
Old Feb 21, 2023 | 09:30 PM
  #43
Cee Jay's Avatar
This is all true. "Nicer" meaning more subdued and smoother. Me, I like raucous and annoying. Redundant? I guess so.
Old Nov 28, 2025 | 08:42 AM
  #44
steadicam's Avatar
So did you ever get you ecm retuned?
Old Nov 28, 2025 | 08:44 AM
  #45
TraxtarXKR's Avatar
I never did... It requires a file from an xkr-s, which I didn't have access to. I do have all the tools to do the flash, though.
There was a lot of gatekeeping around the process for an 13 year old car, and I couldn't find a straightforward procedure to follow. Since the stock HP is enough, I decided to stop and spend my time on other things.
If there was a clearly defined process such as re-naming files and editing a few lines of text, I would attempt it. I never found that, though.
Old Nov 28, 2025 | 09:02 AM
  #46
steadicam's Avatar
Thanks for the quick update, I am really surprised by that.. i would of thought there would be more desire among the membership to do this procedure and pass the info on. Not that want to do it myself, I'm not tracking the car, and on the street 510 is more than enough to get a me in trouble. But I don't like not having the choice, since after all it is mine to screw up.
Old Nov 28, 2025 | 09:23 AM
  #47
Cee Jay's Avatar
The XKR-S engine tune is already resident inside SDD though, in several locations. The files have a shred-out of ZAE for the -S. The /R tune has RAE as a shred-out. SDD only uses the correct files for the car it finds in all of those file locations.
SDD also will only update an already-on-the-car file with a newer file, so the A, B, C, D, E files need to be accurate also or you can use your car to build a nice wall around your patio. (brick wall)
Without rereading this entire thread again to see anything, the center resonators also need to be removed for the -S tune.
Old Dec 7, 2025 | 10:24 PM
  #48
steadicam's Avatar
Why is that? How does the car "know" that it has center resonators? What if you did the retune but did not update to the PAE? Conversely, In my case my car came stock with PAE does that mean it has a different tune than the xkr built without the option? You see what I'm getting at here; Is the PAE worth any hp increase by itself?
Old Dec 8, 2025 | 10:04 AM
  #49
Cee Jay's Avatar
The /R-S tune is specifically FOR a resonator-delete exhaust. Of course it won't 'know'. Just assume, as that is what it was made for. Put an -S tune with resonators and you lost most of any increase that you may have gotten.
Old Dec 9, 2025 | 10:48 AM
  #50
isomorphZeta's Avatar
I've noticed that there's a lot of that with these cars, which is certainly new to me when compared to other communities.
Old Dec 9, 2025 | 11:46 AM
  #51
Cee Jay's Avatar
Doing this involves modifying SDD files in many different locations, A specific version OF SDD, A certain version of existing files on receiving vehicle, and if everything isn't set up just right, running it could brick the car. SDD may also lose it functionality.
It is not a simple procedure.
It will also only gain 45 ponies. Not much gain for a lot of work and risk.
Old Dec 9, 2025 | 01:52 PM
  #52
wymjym's Avatar
think back a few decades...ONLY!
my, how perceptions have changed
wj
Old Dec 9, 2025 | 05:42 PM
  #53
AlexJag's Avatar
Sponsor
You could of had a remap years ago 😆 it's easily done and has more power that XKRS tune you keep talking about. There is no gatekeepers, as iv said years ago , there is too much risk trying to do it with SDD which makes it pointless to do . There are easy user friendly tools these days, we have handheld devices that work through your phones app to flash 620hp and up to 700 HP with more mods.
Just an example of a minimally tuned FType R pushing 700hp
Reach at to Alpha Jag Tuning, AlphaJags.com
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
draguarxkrsgt
Nov 21, 2020 03:14 PM
Evan97
Apr 3, 2019 08:33 PM
rickross
Nov 8, 2017 03:47 PM
kennyboy
Aug 5, 2014 03:05 PM
Robinb
87
Feb 17, 2014 10:17 AM
