Is there a simple way to put grille in without removing entire bumper?
Old Sep 28, 2019 | 10:45 PM
AlexJag's Avatar
Sponsor
Default Is there a simple way to put grille in without removing entire bumper?
So I went to repaint my silver grille into black. Figured out a way to remove them but install looks as it will be very dificult without bumper removal . Anyone got a clever way to put lower and upper grille back in?
Old Sep 29, 2019 | 12:45 AM
kj07xk's Avatar
They won’t go back in the same way that you removed them?
Old Sep 29, 2019 | 05:00 PM
AlexJag's Avatar
Sponsor
No ,you can take it out by pushing the clip with a screwdriver and get the grille out but puting it back in is a different story since clips needs to slip back on unto tab on the grill, has to be done from inside of the grille , unless maybe some special tools could be used.
Old Sep 30, 2019 | 12:09 AM
kj07xk's Avatar
Unless you’ve got a mesh grill, I’d think something like a screwdriver with a 90 degree bend in it might work.
Hook it through the grill near the clip, put the end on the clip, and then pull to seat it.
Old Sep 30, 2019 | 05:39 PM
AlexJag's Avatar
Sponsor
dont see how I can do it with a screwdriver
Old Sep 30, 2019 | 05:59 PM
kj07xk's Avatar
So the clip goes on the backside of that vertical tab that hangs down in the first picture? The grill has a horizontal tab that pokes through the vertical tab?
Will the clip fit through the grill? If not, maybe trim the clip narrower so it will?
Since I haven't taken that apart, I'm trying to visualize how it fits together.
What I'm thinking, is if the clip will fit through the grill, you could hold it in place over its tab with something like a forceps, then using an 'L' shaped tool (like a bent screwdriver), put pressure on the back of the clip (by pulling forward) to press it onto the grill's tab (all the while, holding the grill in place). Just gotta grow a third arm.
And since you can't see what you're doing back there, you're working blind, and have to go by feel.
Old Sep 30, 2019 | 06:35 PM
AlexJag's Avatar
Sponsor
yes clip goes on the tab that goes through to the other side. Il give it a try . Another option I thought about was drill small holes and screw the grill in from the front
Old Sep 30, 2019 | 06:54 PM
jahummer's Avatar
Pulling the bumper is not that hard, I’ve done it 4
or 5 times. Someone here did the clips
from underneath, by dropping the undertray and reaching up that way. The clips take some
force to replace.
Old Sep 30, 2019 | 10:32 PM
AlexJag's Avatar
Sponsor
force to replace.
Jahummer Any links or directions on removing the bumper would be apriciated!
Old Oct 1, 2019 | 07:36 AM
gkubrak's Avatar
You guys are wild with these screwdrivers and drilling holes ... just remove the bumper, it takes 20 minutes. Do it right!
- Remove wheel and tire
- Remove undertray
- Remove or pull back wheel arch liner
- Disconnect electrical harness
- Remove a few screws
- Remove a few plastic clips from top of bumper
- Pull off
Removing the grille will become obvious when the bumper is off
Old Oct 1, 2019 | 08:23 AM
TexasTraveler's Avatar
- Remove undertray
- Pull off
I agree with Jahummer and gkubrak, pulling the bumper is easy.... Just an added note you don't even have to pull the wheels or the undertray....
Old Oct 1, 2019 | 06:38 PM
AlexJag's Avatar
Sponsor
Yes figured it out , bumper isn't too difficult to remove. I will say the clips for the grill are from the 😈 , easy to take off but a pain to put back on , no way would be able to put them back on from the front without bumper removal.
Old Oct 1, 2019 | 07:45 PM
badicedog's Avatar
That looks pretty straight forward
Old Oct 2, 2019 | 08:09 AM
shemp's Avatar
might as well change yer air filters....
Old Oct 3, 2019 | 08:02 PM
AlexJag's Avatar
Sponsor
Red growler next.
Old Oct 4, 2019 | 03:20 AM
Originally Posted by AlexJag
Yes figured it out , bumper isn't too difficult to remove. I will say the clips for the grill are from the �� , easy to take off but a pain to put back on , no way would be able to put them back on from the front without bumper removal.
So that's what they look like without the Pedestrian Protection System rubbish we have to have in Europe.
Interesting to see you didn't remove the undertray. I've always removed it. How easy was it to refit the bumper with the undertray in place?
Old Oct 4, 2019 | 08:21 AM
GGG, I have removed front bumper 2-3 times and never removed undertray. You just have to align it with the bottom of the bumper before you start reinstalling bolts...
Old Oct 4, 2019 | 12:28 PM
gkubrak's Avatar
Are you going to paint the fog light cover grill to match?? I did that with mine in silver and it looks great.
The black looks nice too, good job.
Old Oct 4, 2019 | 03:31 PM
AlexJag's Avatar
Sponsor
I'm thinking painting the mesh only part in the covers. You went with silver grille and covers? Pics?
Old Oct 4, 2019 | 08:33 PM
gkubrak's Avatar
Yeah that's what I meant. Just have to carefully mask off the surrounding areas. Red growler is the way to go too!
