Thinking of replacing 2007 XKR with a 2012...
Hey guys.
I'm thinking of swapping in my 2007 XKR for a newer model. I know about the exterior facelift, gearbox, trim and engine improvements.
But can someone tell me if there's any significant changes over the multimedia technology? I.e. has the audio/bluetooth/sat nav had any sort of refresh?
For example, the bluetooth in my 2007 XKR doesn't appear to work with the latest Android OS, which I gather is a common problem. The Sat Nav is a little slow to respond. And the iPod Audio Connectivity Module has extremely limited user interfacing features. E.g. I can change track from the wheel, but no audio information is presented on the display.
I'd like to know if these things have improved!
Thanks.
Thanks.
Multimedia in a 2012 XKR may be all the same as in a 2007, it depends of a build date. The multimedia was upgraded in a 2013MY IIRC. Anyway, it's still possible to retrofit a multimedia from a current XF
It's possible, but it will require a replacement of the IAM module and touchscreen. Also it will require some works with wiring and MOST and some reprogramming. But it can be done.
