Tips on rear wheel bearing replacement
Old Jun 13, 2023 | 10:53 AM
chaznatr's Avatar
Default Tips on rear wheel bearing replacement
I have been tracking down the cause of the noise while driving on my 2014 XKR 5.0
I am now thinking it is a rear wheel bearing. That being said does anyone found a method to replace them without buying the special jaguar tools, or having a Jag shop do the work? I am allergic to spending money on maintenance I can perform myself.
Thank you in advance
Chazz
Old Jun 13, 2023 | 07:11 PM
steve_k_xk's Avatar
the 5.0 required the bearing to be pressed out and obviously the new one to be pressed back into the hub unlike the 4.2 which is simply bolt in .....have you got a press ???
Old Jun 13, 2023 | 07:54 PM
chaznatr's Avatar
Default Yes
I do have a press in my garage, my biggest concern is getting it off the axle. The shop manual warns about using a hammer and I’m not sure if a puller could get it loose. The other concern when pressing the bearing in if there are any tricks to make sure it goes in straight.
the shop manual has a lot of warnings
i really appreciate your response, it leads me to believe it can be done
Old Jun 14, 2023 | 02:49 AM
JonWat's Avatar
Put the new bearing in the freezer overnight & heat the hub with a blowtorch then she'll drop straight in.
Old Jun 18, 2023 | 03:33 PM
hafren's Avatar
Chazz
So can you describe the noise you are experiencing and under what operating conditions do you hear it?
Old Jun 18, 2023 | 05:22 PM
chaznatr's Avatar
Default Wheel noise
hafren
its a rhythmic “groan” which gets louder and faster as speed increases. I don’t feel any vibrations from it. When I turn to the right it gets quieter.
I started taking the drivers side (US /left) rear apart but got nervous trying to remove the wheel hub assembly off the axle shaft. I also noticed my toe end rod ball joint dust cover was torn.
I put everything back together and ordered a pair of tie rods with ball joints.
how do you recommend removing the hub from the axle when I get around to doing the process again?
Old Jun 18, 2023 | 05:44 PM
steve_k_xk's Avatar
Some times you can tap the axle back in to release it from the hub plenty of penetration spray and use a drift otherwise you'll need to order a hub remover
Old Jun 18, 2023 | 06:21 PM
chaznatr's Avatar
steve_k_xk
thank you I will give that a shot. The shop manual made me really nervous about how to remove it.
Chazz
Old Jun 18, 2023 | 08:14 PM
steve_k_xk's Avatar
Of course make these cars unworkable and pay the $250/phr rate at dealer haha
Old Jun 18, 2023 | 08:25 PM
chaznatr's Avatar
I identify as a cheap ******* when it comes to automotive repair. The nice thing about the Jag is when I do a repair properly it feels extra good. I’m looking to have that extra good feeling when I fix this noise
Old Jun 19, 2023 | 02:45 AM
steve_k_xk's Avatar
Always come out with that sense of accomplishment and fulfillment when you're able to work on your own vehicle)))
Old Jun 19, 2023 | 03:28 AM
JonWat's Avatar
hafren
If it's only the dust cover is torn but the joint is fine you can buy replacement boots.
mcphill
Apr 13, 2023 11:37 AM
Madbrad
Jun 9, 2016 09:16 AM
TN8Shooter
Jun 5, 2012 12:18 PM
V6 JDT
Mar 4, 2011 11:48 AM
walkman1
Nov 16, 2010 11:47 AM
