Too Good To Be True?
Cars for Sale: 2007 Jaguar XK Coupe in Manassas Park, VA 20111: Coupe Details - 332477352 - AutoTrader.com
I saw this ad for a 2007 XK coupe for $23K. It has 60K miles but still, it seems to be priced way low, so I suspect it's been hit or has another underlying issue. I am tempted just to go take a look at it though.
Assuming the cosmetics and mechanics check out it's a bargan. Get an Xk owner to go with you for the check ride and inspection. The details can be expensive to correct. For instance, a blown shock is upwards of $1200 to fix. An ashtray that won't latch open is a $600 fix.
So far, at least, these 07 and up XKs are noted for their reliability. This car looks good in silver/gray and the 20" wheels are an extra cost option.
If you keep a car indefinitely, go for it. If you usually keep a car 2 years or less, keep in mind that 100K miles plus Jags are hard to sell.
I just ran an AutoCheck on it and it has 3 accidents on the report (2 with another vehicle and 1 with a tree). I'm guessing it was driven by an absolutely incompetent driver.
If it's too good to be true, it usually is!
I thought it got rear-ended because there was a noticeable gap between the rear bumper covering and the fender. However, with three accidents, there probably isn't an original piece of sheet metal left. I suspect the maintenance was equally shoddy.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
Sep 2, 2015 11:43 AM
