Touch Screen
Old Sep 20, 2024 | 02:19 PM
slb07jagxk's Avatar
Default Touch Screen
My touch screen has an imprint image. Cannot get it out It looks like a rectangle. Probably needs replaced. Thoughts? It is a 2010 XKR
Old Sep 21, 2024 | 02:33 PM
McJag222's Avatar
I don't think there is any way to get rid of screen burn. If yer handy it may be possible to get a used unit and swap the display. That way you don't have the display programmed to the car.
Old Sep 23, 2024 | 11:44 PM
slb07jagxk's Avatar
So, what you are saying is that I can get a used unit and not have to get it programed? It will work as new?
Old Sep 24, 2024 | 04:11 PM
Sean W's Avatar
The unit has to be from an XK, not an XF though. There have been a few threads here and there where people say they are interchangeable but they aren't. The XF uses a different climate module so the climate controls won't work. I think, but am not sure, that you also need one from 2010 onward. I have an 07 and a newer 2010 screen isn't interchangeable. (Perhaps for the same reason as an XK to XF swap. though I'm not certain of the reason) The 07-09 screens may be backward compatible, but suggest you look for one 2010 onward.
Old Oct 7, 2024 | 04:18 PM
slb07jagxk's Avatar
Default Touch screen/ Dash
Thank you for the info. Also, I have notice that the small info screen between the speedometer and tach is fuzzy or distortated.
Any idea on how this can be? Looks like it has condensation.
Old Oct 8, 2024 | 09:41 AM
DeeDoubleYou's Avatar
I believe the display is a 7" inch Toshiba LTA070D010F TFT LCD panel.
-df
Old Jan 29, 2025 | 08:10 AM
slb07jagxk's Avatar
AS I check out my touch screen, it seems that it has stopped working. Touch no longer works and now the fan control /or fan has stopped working. It looks like it may be all one unit.
Has anyone had this issue?
BLD
Feb 12, 2024 01:30 PM
JimmyCalabasas
Feb 23, 2023 02:50 PM
silversurfer1221
Oct 1, 2021 02:05 AM
coleman645
Sep 2, 2018 10:29 AM
sherbercars
Aug 6, 2011 03:20 PM
