TPMS fitment question
Old Apr 14, 2017 | 10:17 AM
Sean W's Avatar
Default TPMS fitment question
Well I swapped out my front antenna L to R after getting the "Tire not monitored" message (L front tire). Message was gone for maybe a week then came back, same wheel. So I'm going to check for a short but after 10 years I suspect it's the TPMS.
I plan to buy a set. Here is my question. I understand the U.S. models use the 315 mhz units.
If I search for VDO brand by car, they are around $60/ piece give or take.
If I search for VDO brand by frequency, they can be had for $25/ piece give or take.
Does it matter if I buy TPMS intended for Lexus/ Toyota, if the frequency is the same?
Old Apr 14, 2017 | 11:02 AM
Sean W's Avatar
Ok I think I answered my own question. There are universal programmable TPMS and vehicle specific. The programmable ones may or may not work, they claim 95% of all vehicles. I guess I'll just bend over and buy the ones for my XK.
Old Apr 14, 2017 | 05:37 PM
kj07xk's Avatar
You can use either the VDO SE53001 or the SE53004.
The SE53001 is what came with the OEM wheels, and the SE53004 is a newer version. I bought the SE53004's and they work just fine.
Old Apr 17, 2017 | 11:27 PM
richzak's Avatar
As I have stated in several other threads, these TPMS are an exact fitment to the Jaguar. I had these installed at Discount Tire and the Jag XKR learned the TPMS within 5 minutes.
Best price anywhere. Fast Delivery.
Amazon Amazon
Doubtful you will find a lower price. Don't mess with any other brand or model. Go OEM.
Old Apr 24, 2017 | 08:50 PM
Sunkist's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
May be a dumb question, but will these work on my 2014 XKR? Most everything I see mentions up to 2013. I have noticed that many parts are the same from at least 2010-2015, but often times descriptions and listings don't go beyond 2012. Is this a correct assessment of what I've been looking at or am I totally off base and everything changed in 2014? Any insight into this will be greatly appreciated. I've only been a Jag owner for a few weeks, but thanks to all of you here, I feel like I know WAY more about my car than the average car owner.
Old Apr 24, 2017 | 09:24 PM
Ranchero50's Avatar
I want to say the frequency changed around then.
Old Apr 24, 2017 | 10:39 PM
Sunkist's Avatar
Still not completely for sure, but after checking a few different parts sites, it appears Jaguar combined all of the old part numbers into one part number covering a number of models from both Jaguar and Land Rover. I found some refurb units, but while they claim to be compatible with the XK from 2007-2014, it says that compatability for the XKR is only 2007-2011. It doesn't make sense that Jaguar would make a change like that only on the XKR, but stranger decisions have been made. Since I can go to the tire shop and have them test whether or not the sensors are working, is it reasonable to expect that the tester can determine frequency as well?
Old Apr 24, 2017 | 11:05 PM
richzak's Avatar
The Siemens VDO SE53001 is not the correct fitment for a 2014 XKR.
The following TPMS are compatible with your 2014 XKR. I would suggest staying away from the Oro-Tek TPMS as I had a very bad experience with the brand.
Amazon Amazon
This should help.
Old Apr 25, 2017 | 03:08 PM
Sunkist's Avatar
Did some more digging, and it's still not clear. But I found these...anyone know of or have any experience with this make?
Set 4 TPMS Tire Pressure Sensors 315Mhz Metal for 12-14 Jaguar XKR | eBay
Old May 20, 2017 | 10:49 AM
Sean W's Avatar
Well thanks again Richard. I did find them a bit cheaper, but not by much.
I installed them but the car wouldn't recognize them on a 20 mile spirited drive, so I had to pull out SDD and recalibrate. So good for another 10 years.
Attached Thumbnails TPMS fitment question-screen-shot-2017-05-20-10.42.37-am.png
Old May 20, 2017 | 11:17 AM
davchr's Avatar
What is SDD?
Old May 20, 2017 | 11:35 AM
Sean W's Avatar
Originally Posted by davchr
What is SDD?
Symptom Driven Diagnostics. It's Jaguars OEM vehicle maintenance software. Used on a laptop with VCM (Vehicle Control Module) that plugs into the OBD II port.
It's what your dealership uses. I own it as I do most all of my own repairs, except where limited by skill set (I don't do body work) or lack of tools (I no longer have welding equipment for exhaust work)
Old May 24, 2017 | 12:34 AM
pk4144's Avatar
Related....
Has anyone ever simply disconnected the system? My "TPMS" consists of my eyes and a high-quality tire gauge, and after a cross-country trip I am pretty much done with the "Check Tyre Pressure" warning light, which seems unconnected to physics or reality.
Any thoughts or advice would be appreciated.
Old May 24, 2017 | 01:21 AM
Simon Tan's Avatar
I recently started having issues as well with the TPMS on my car. First it said one tire was low, then said later the same day it was fine but another tire was low. So I checked and the second tire was in fact a little low. Then the warning went away for a day then came back again saying instead that there was no reading for that tire. Then the next day nothing. Then today I get the warning again for two tires. It did suddenly drop 30 degrees in Texas today, but this is all pretty annoying. It would seem to me if something is going bad, it's the receiving end since it seems unlikely all four TPMS sensors would suddenly go bad in a matter of days. Any ideas?
Old May 27, 2017 | 12:08 PM
Sean W's Avatar
Originally Posted by pk4144
Related....
You can disable TPMS via the CCF file in IDS/ SDD.
