TPMS/OEM Parts Online?
Old Feb 19, 2008 | 06:22 PM
GhostriderXKR08's Avatar
Default TPMS/OEM Parts Online?
Is there any website that sells Jaguar OEM parts for less than the dealer? I need to buy 4 TPMS sensors plus the tool to put it on (according to the dealer).
Also,I was told the TPMS runs either 315 MHZ or 433 MHZ. Just want to confirm U.S. model XKRs run 315 MHZ?Thanks.
Old Feb 20, 2008 | 05:40 PM
jag_genius's Avatar
Default RE: TPMS/OEM Parts Online?
i can probably get them for you cheaper then the dealer.. and there is no special tool.. the tires do have to be broken down to get the valve sensors in.. just need socket and rachet to install but that hold the sensor in.. i think the frequency is 315 mhz i check tomorrow
Old Feb 21, 2008 | 08:58 AM
ORIGINAL: jag_genius
Thanks. I'm planning to get aftermarket wheels in the summer and just seeing if it's worth buying new sensors with valve stems or if it's too expensive then just taking off the sensors on the OEM wheels. I was told North America uses 315 mhz but just want to double check also. Thanks.
Old Feb 21, 2008 | 04:41 PM
FactoryJaguarTech's Avatar
Definitly 315Mhz. You should be able to transfer the sensors from your wheels to the aftermarket ones. At least that is what we do. Only had one set of wheels that we couldnt fit into.
Old Feb 21, 2008 | 04:48 PM
ORIGINAL: FactoryJaguarTech
Thanks FactoryJaguarTech for the info. Can you give alittle more info as to why that one set woudn't fit....after hearing that, I'm alittle concern if the sensors will or will not fit my aftermarket wheels. Do you know which wheel brand it was? Thanks!
Old Feb 21, 2008 | 08:29 PM
jag_genius's Avatar
but where FJT is, those guys in florida like to play with there 20's and 22's certainly some low quality rims made in china.. the sensors will not fit.
Old Feb 22, 2008 | 04:25 PM
LOL
dsnyder586
Dec 29, 2024 07:39 PM
Scott B
Oct 24, 2015 01:29 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
1100me
Sep 7, 2015 06:26 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
