Transmission
Old Jul 16, 2022 | 12:29 PM
Wayne T's Avatar
Default Transmission
I have a 2007 XK that needs a rebuild transmission and Ican not locate one. Are there any suggestions where I can have the one in the car rebuild? The car is located in East Tennessee.
Old Jul 16, 2022 | 02:09 PM
Sean W's Avatar
Try expanding your search: I think others should weigh in regarding compatibility but the ZF6HP26 Transmission was used in the following vehicles:
2001–2008 BMW E65/E66 7 Series
2002–2008 Jaguar S-Type
2003–present Jaguar XJ
2003–present BMW E63/E64 6 Series
2003–present Range Rover
2004–2006 BMW E53 X5 V8
2003–present BMW E60 5 Series
2005–present BMW E90 3 Series
2005–present Land Rover Discovery
2005–present Ford Falcon (BF, FG)
2005–present Ford Territory (AWD Versions)
2005–2008 Lincoln Navigator
2006–present Range Rover Sport
2007–present BMW E70 X5
2007–present Jaguar XK8/XKR
2007–present Maserati Quattroporte
2008–present BMW F01/02 7 Series (except 760i/Li and Hybrid 7)
2008–2011 Kia Mohave
2009–present Hyundai Genesis V8 4.6L
2009–present Jaguar XF
Old Jul 16, 2022 | 02:58 PM
Wayne T's Avatar
Thanks, I will look into it.
Old Jul 16, 2022 | 06:53 PM
jahummer's Avatar
Trying to understand your question...are you saying you're unable to locate a transmission specialist to repair your transmission?
Old Jul 16, 2022 | 07:08 PM
Wayne T's Avatar
Yes, I am looking for one.
Old Jul 16, 2022 | 07:09 PM
jahummer's Avatar
Knoxville or Chattanooga or?
Old Jul 16, 2022 | 07:15 PM
ralphwg's Avatar
In looking for a used transmission. Checkout Pacific Motors in the Detroit area. They are breakers. A second source is Jaguar Heaven in CA.
Old Jul 16, 2022 | 09:37 PM
Wayne T's Avatar
Knoxville preferred or Chattanooga as a back up.
Old Jul 16, 2022 | 09:39 PM
Wayne T's Avatar
Thank You
Old Jul 17, 2022 | 07:31 AM
guy's Avatar
guy
Who says you need a rebuilt one? A ZF service center? Did you ask them about a quote for repair?
Old Jul 17, 2022 | 09:22 AM
Wayne T's Avatar
My repair shop told me and cannot find a replacement. I have not heard of a ZF service center but will look for one. It appears he shop is only willing to switch out the transmission and I need a transmission shop that does repairs on the transmission.
Old Jul 17, 2022 | 10:12 AM
Kongo1's Avatar
What are the symptoms that are causing them to say the transmission needs to be replaced?
Old Jul 17, 2022 | 10:15 AM
Stuart S's Avatar
See:
https://aftermarket.zf.com/us/afterm...transmissions/
Old Jul 17, 2022 | 10:25 AM
jahummer's Avatar
It’s not uncommon for service centers to ONLY want to replace the entire transmission with a certified rebuilt one as it’s quite easy to do compared with performing a rebuild in house.
Old Jul 17, 2022 | 10:34 AM
jahummer's Avatar
Have you tried AAMCO transmission rebuild service in Knoxville? I know they’re a national chain BUT they do have a lot of experience with rebuilding ZF transmissions fitted in JLR vehicles. Also a specialist named Marshall Transmission Service claim to the the oldest and largest rebuilder in Knoxville with the ability to service European marques.
https://marshallstransmissions.com
Im not endorsing anyone just sharing what I’ve found.
Old Jul 17, 2022 | 01:56 PM
Wayne T's Avatar
Thanks, I will check them out.
Old Jul 17, 2022 | 02:01 PM
Wayne T's Avatar
I received an error code and the transmission stopped shifting. The error code was for the pressure control solenoid control. One problem that could relate to that code was low transmission fluid. The transmission was just serviced due to a transmission pan leak. The shop reported that it was 1 and a 1/2 liters low. They filled it up and stated that the transmission is still slipping and needed to be replaced.
I am picking it up on Monday since they cannot locate a rebuild transmission and hope to find another transmission shop.
Old Jul 17, 2022 | 07:09 PM
jahummer's Avatar
Could simply be the mechatronics which's quite easy to R&R with the pan off. Since it's such a commonly fitted transmission to so many marques there's quite a few specialists services available for just this.
Here's one for only $300 on Amazon.
Amazon Amazon
There's others out there as well.
rez1only1
May 23, 2026 06:29 AM
WldCat
Aug 12, 2020 11:55 PM
robbing
Oct 1, 2015 11:24 AM
britannia
Jul 18, 2011 03:56 AM
