Transmission Fluid: OEM or ZF Fluid 6
Old Nov 22, 2019 | 09:52 PM
DGL's Avatar
DGL
Default Transmission Fluid: OEM or ZF Fluid 6
I was going through the member classified market section and found a member, patrickw813, selling a XFR,, which has had the transmission fluid changed. It specifically said he used OEM transmission fluid and NOT ZF Fluid. Would not ZF Lifeguard 6 be the same or better.
Old Nov 22, 2019 | 09:57 PM
Queen and Country's Avatar
Ravenol makes the fluid for ZF
Now Ravenol sells direct. Its called lifegaurd6
I have a black friday coupon if you need.
Old Nov 22, 2019 | 10:22 PM
DGL's Avatar
DGL
Thanks for the offer. I already bought 7 liters. I was just wondering if the OEM Jaguar fluid is the preferred fluid. If you want to email or pm me the coupon I'll stock up on it if it's a good price.
Old Nov 22, 2019 | 10:26 PM
OzXFR's Avatar
Yep, I'm a bit confuzzled by this.
I have read countless times that if you are doing an auto trans fluid "drop and replace" or "flush and replace" and you have the ZF 6HP26/28 as fitted to all early XFs you simply MUST use ZF Lifeguard 6 fluid and anything else risks at least poor functioning of the gearbox if not damage to it. Same with the later ZF 8HP70, it's Lifeguard 8 or nuffin.
And why would JLR pay squillions to ZF for their gearboxes and not use their fluid as the factory fill?????
Fair enough that there may (now) be perfectly good alternatives to the ZF Lifeguard fluids but were they really around back 11 years ago when the XF first came out?
Old Nov 22, 2019 | 10:49 PM
Cee Jay's Avatar
Originally Posted by DGL
........... I already bought 7 liters................
I did a drop & fill, it took just over 9 liters to fill it. I'd purchased 12 quarts, still have two unopened. I hope you don't have a problem, such as What the heck would you do if Not Full and no more fluid to add?
Old Nov 22, 2019 | 11:54 PM
So I clicked on the email they sent special offer- come to find out they posted the coupon on their website too.
All the fluids are here including the 8hp (for Ftype)
https://www.blauparts.com/shop-parts...-atf-4900.html
Old Nov 23, 2019 | 12:10 AM
DGL's Avatar
DGL
Wow, I only bought 7 liters. I thought I got 1 extra. I guess I should get 5 more. Not having enough would be a problem.
Old Nov 23, 2019 | 09:03 AM
DGL's Avatar
DGL
I'm confused. The below ZF video says 5-6 liters for an oil change. I'm not doing a flush. Do I still need over 9 liters?
Old Nov 23, 2019 | 10:51 AM
Cee Jay's Avatar
All I can say about HOW MANY liters to refill is what I personally experienced. Would it have made a difference to me if I'd only had seven liters? Yeah, I'd have my car stuck on a lift, totally undrivable until I got some more fluid from somewhere. That would be a very bad thing.
Maybe other people have had different experiences, although I'd not know how. Same car; same transmission; same pan; same fluid. Can't see how it'd be different. 9-1/2 quarts, just a touch over 9 liters. Course there was a few ounces left in the filler tube upon completion, so let's call it 9 liters.
Dunno, man. Better Safe than Sorry?
Old Nov 23, 2019 | 10:52 AM
sov211's Avatar
I am not sure why there is any confusion...the "OEM" Jaguar-branded, and the Land Rover-branded transmiission fluid IS the ZF fluid with a different package and label.
Old Nov 23, 2019 | 02:12 PM
DGL's Avatar
DGL
Thanks. Much better to have a few left over than not have enough.
Old Nov 23, 2019 | 07:41 PM
And the ZF branded fluid is Ravenol in a different package and label as ZF is not a lubrication manufacturer.
Old Nov 23, 2019 | 07:57 PM
OzXFR's Avatar
Ahh, that makes sense now!
Although I am guessing that Ravenol made a deal with ZF not to sell this fluid for a few years after they started making it, other than selling in bulk to JLR.
Old Nov 23, 2019 | 09:37 PM
Sean W's Avatar
Oh not just Jaguar. ZF transmissions (the same as ours) are in Hyundai's, BMW's, Audi's and more.
Old Nov 23, 2019 | 10:45 PM
In general Ravenol resisted selling to consumers in USA, they simply did not exists.
This year they launched a blitz, yes German style and offering everything to everybody.
You wont believe the packaging either, there is a serial code and a USA website on the bottle, so I go to it and enter the number, it tells me its authentic, to test I try 1 digit off, and it says fake. So totally catered to the consumer as opposed to pro, even with a pull-out pour spout built into bottle.
Which Ironically is the reason I wont use castrol anymore, because they only way I can get here in the States is bootleg, i.e. someone is selling something they are not meant to be selling, which means consumers being bent over a barrel, or accepting old stock.
I understand they need to recuperate their R&D, but it wont help me get into heaven for looking out for their well-being.
So they now have a UK specific website, German and USA. Note the name of the UK site
https://www.ravenol-direct.uk/raveno...8hp-fluid.html
greenforest56
Dec 16, 2022 09:29 AM
cyber3d
Mar 15, 2017 12:04 PM
kelbymorgan
42
Mar 31, 2015 05:32 AM
Charlietuna
19
Aug 26, 2012 08:01 AM
Leedsman
General Tech Help
Apr 20, 2010 10:22 PM
