Transmission Pan Part #
Old Nov 10, 2013 | 09:14 AM
dkeuper's Avatar
Default Transmission Pan Part #
The Transmission Pan of my '07 XK is leaking badly, or it might just be the sleeve.
Anyway I'm going to replace the pan, sleeve and tranny fluid while I'm at it.
Can anyone help me finding the right part# for the Pan?
I fould the following:
Part Number: ZF1795966
Part Number: ZF1965479
Part Number: ZF1966939
2007 Jaguar XK Auto Trans Oil Pan - Buy 2007 Jaguar XK Auto Trans Oil Pan Online
Old Nov 10, 2013 | 12:07 PM
britannia's Avatar
Go to gaudinmotorcompany.com or call them; very helpful and good prices. They are in Las Vagas; I use them for both our Jags., XK8 and XK............
Cheers, Adrian
Old Nov 10, 2013 | 01:11 PM
CleverName's Avatar
According to my documentation, the OEM number is C2C38963.
(See item 23 in attached)
Find out what crosses to it....
BOL
Vince
File Type: pdf
Old Nov 11, 2013 | 03:49 AM
Knowing that a ZF6HP fluid change on the earlier XK8 model was a complicated procedure, I was surprised to see in the X150 Workshop Manual that it appeared to be a straightforward drain and fill.
However on reading the fluid level check procedure, I see it is the same requirement to do this with the fluid at between 30 degrees and 50 degrees to obtain the correct level.
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
Dymaxxion
Sep 4, 2015 02:40 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
