tried to replace thermostat housing... no thankyou
Old Oct 12, 2014 | 06:58 PM
apost8n8's Avatar
Default tried to replace thermostat housing... no thankyou
When I last had the car in the shop the mechanic noted the thermostat housing "upper assy" had some cracks with slow coolant leaks.
A few weeks back the radiator fans continued after shutting down for 5 minutes or so. I thought the thermostat had stuck but when I checked fluid levels the reservoir was mostly empty.
I topped it off and and continued to drive with no more overheating. I reviewed the threads here on overheating/thermostat/housing replacement and thought I give it a shot. Bought the upper assy online for $118 delivered and decided to dive in today.
Removed the cover... no problem. Removed a couple hoses and a reservoir and then realized that I would have at least another dozen fasteners that i could barely see and numerous hose clamps.
After an hour in I just gave up and starting re installing everything. I'm going to the shop in a week. I figured the likelyhood of screwing something up and spending my entire sunday under the hood were not worth the cost savings.
I feel defeated.
I prefer driving the car than working on it. thanks for the motivation anyway.
Old Oct 13, 2014 | 12:43 AM
Ngarara's Avatar
Get yourself a copy of the workshop manual online (comes as a set of PDFs) - that way you'll have some idea of what's involved in the job before you get started.
Old Oct 13, 2014 | 02:10 PM
racerxf12004's Avatar
It really is outragious that they keep making cooling systems parts out of plastic. This has to be the goofiest idea ever on a car. They dont mind spending tons of $$$ on back up cameras & infotainments systems...oh lets make the parts that coolant at 220 degrees flows through out of plastic.....waterpumps, thermostat housings should always be made from aluminum.
Forcedair1
Sep 8, 2025 01:57 PM
Doug
Feb 27, 2019 01:31 AM
KarimPA
Sep 12, 2015 08:15 AM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
