Trunk release 2007 XKR
Old Apr 12, 2022 | 01:57 PM
SilentThunder's Avatar
Default Trunk release 2007 XKR
When I use the remote to pop the trunk, it does that but the trunk does not open. Not sure if this normal or my trunk shocks are weak. Is functioning normal?
Old Apr 4, 2025 | 11:29 AM
KurtC's Avatar
Dimopoulos4, I am a fellow 2009 XKR Portfolio owner a little north of you in Tyler. I mounted a CTEK battery maintainer in my trunk using the same jump-start leads as your device (+ to the jump start post inside the back left side of the trunk and - to the stud left of the spare tire). If yours is a charger and not a maintainer, I'd switch it out for a maintainer so you can leave it plugged in without worry.
Old Apr 7, 2025 | 10:25 AM
KurtC's Avatar
Sorry, previous reply was posted to wrong thread. Moderator please delete if possible. Thanks.
Old Apr 7, 2025 | 10:30 AM
guy's Avatar
guy
If you are expecting the cargo area lift gate to actually rise high into the air... that is not the way it was designed.
Old Apr 7, 2025 | 11:58 AM
Cee Jay's Avatar
If you expect the lift gate to stay up after you raise it manually, it should do that. If you raise it manually and it lowers by itself, your lift struts are weak.
Old Apr 7, 2025 | 02:32 PM
Stuart S's Avatar
That's normal. There is no power lift or close mechanism. You have to manually lift and shut the trunk lid after it is unlocked. It can be unlocked with the Smartkey, by pressing the button on the dash, or the button on the trunk.
Note that If the trunk doesn't latch closed, the doors won't lock. See this thread:
Replace trunk latch mechanism.
The expensive OEM Jaguar part is actually a Ford part, available used and cheap on eBay.
gibbon
Dec 30, 2017 08:30 PM
jlpatton
Mar 9, 2015 07:39 PM
MonticelloLV
May 17, 2012 11:05 AM
Wild Bill
Sep 16, 2008 01:27 AM
